convo pros
convo pros
what size do i neeed for an 01 z28
i know 15x4 with 1.75 back space on the front
now for the back do you run the 15x7 or the 15x8.5 and with what back spacing.
and is our bolt pattern 5x4.75
i know some of these fit with out grinding or using spacers but they stick ou a little in the rear
please let me know
please let me know
Moderator
What size rear wheel you go with depends on how wide of a tire you choose.
In the Convo Pro wheel line, only the 15x7.5 with 5" BS fit without grinding or spacers and looks good.
The 15x8.5 with 5"BS sticks out a bit but still work, also no grinding or spacers needed.
The 15x9 with 6.5”BS look and fit well but do require some grinding.
Our bolt pattern is 4x4.75.
Go here to see how the Convo Pros look.
http://www.wheels.ls1tech.com/gallery/main.php
John
John
