How do i remove the bottom spring seat?
Old 03-21-2007, 07:05 PM
noxiouSS's Avatar
Default How do i remove the bottom spring seat?
Taking apart some stock heads, is the valve guide pressed in?
Old 03-21-2007, 07:17 PM
SSpdDmon's Avatar
Some years had a one piece spring seat/valve seal.
Originally Posted by LS1HowTo.com
Now, if your cam/spring package came with new seats, you're going to need to remove the valve stem oil seals. Using a pair of pliers, grab the oil seal as shown in the picture and wiggle/pull upwards and work the seal off.
If you have a 2001+ car, the oil seals and stock spring seat will be one piece and you just pulled both out. If you have a 2000 or earlier, the oil seal will be a small black or brown thimble shaped thing, and you can now remove the stock spring seat (using a pen magnet is easiest to pick it up).
Old 03-21-2007, 07:52 PM
JPH
JPH's Avatar
VALVE GUIDE is pressed in.
Old 03-21-2007, 08:01 PM
SSpdDmon's Avatar
Doh! Don't know what I was thinking.
Old 03-21-2007, 08:56 PM
noxiouSS's Avatar
cool, thats what i thought
Old 03-22-2007, 05:08 AM
vettenuts's Avatar
Not sure I follow, the question in the thread title is valve seat, but you are asking if the valve guide is pressed in. Are you changing the guides?
Old 03-22-2007, 08:54 AM
2xLS1's Avatar
The title is spring seat. If they have the separate seat/seal, you remove the valve guide seal with a pair of pliers then remove the spring seat. If they have the one piece seal/seat, the seat comes off with the seal. Same thing, grap them with a pair of pliers.
Quick Reply: How do i remove the bottom spring seat?
