05 5.3 in my 66 truck and my autometers
I recently put a 05 L33 all aluminum 310H.P. 5.3 in my 66 C/10. I have run into some problems with the tach and the speedo. The main problem is that all of the guage wires for the 05 are serial ported and the guage sender wont read the signal. I have sent the tach to autometer twice and they still cant get the damn thing to work. They converted the tach to a 5 volt square wave that is supposed to read the 05 signal but still nothing. The programmable speedo soesnt seem to be picking up the speed sensor either. I had no problem with temp, oil pressure, and fuel just the other two. Any of you guys had this problem? Any suggestions are appreciated.
Sweet truck, I miss my ol' '62 that I had in high school,283 4sp saginaw stump pullin gears, couldnt afford gas in that thing. Can't help with your ? sorry, just wanted to comment on your truck.
Huh... Thats strange. Did they change the outputs of all of that stuff for the 05 models???
I woudl think that the tach would work without issue. The speedo should work too. But did you try hooking the speedo up to through the PCM or directly off of the speed sensor? Because they should be two different outputs. I hooked my speedo through the PCM and it worked (99 f-body harness), and I was told it should have worked through the speed sensor as well. And the tach just comes off the PCM too. Also, Im pretty sure the gauges in the 99 were serial data as well...
Have you talked to someone like John from Speartech about this? He might have some insight into whats going on...
Justin
Justin
My truck had a 283/350 combo and you arent lying bout being gas hogs!! The 5.3/4l60 combo gets well over 20 on the highway
Originally Posted by fastrucken
I cant help you with your questions, but was wondering what you did for your exhaust, did you use headers??
Graham
Graham
Justin
Justin
Steven
