true duals
true duals
i have a 97 lt1 with bbk short tube headers, and i am wanting to get custom true duals with two twister mufflers dumped before the rear end. My car is also lowered with the eibach pro kit in the front and eaibach sportlines in the back. i have some prokits for the back if needed for ground clearance. Does anyone know if i will drag the ground with them? should i use 2.5 or 3 inch pipe? and what is the best way to run duals with the best ground clearance.
By the way does anyone have any audio or video of a cc306 on duals? just wandering what my car might sound like with duals.
Thanks for the help, Josh
Not trying to be an *** but you might wanna . There has been plenty of threads on this topic and simple search will provide you with plenty of info. If you already have well then, my bad.
