LS6 or LS2 head ID.
LS6 or LS2 head ID.
I hope this isn't a topic covered countless times but I haven't been able to find the answer yet.
Iam to understand the LS6 and the LS2 both used the 243 heads how can I tell the difference?
I would think the LS6 head would be the more desirable one due to the lighter sodium filled exhaust valves. Correct?
Thanks for any help on this, Carl.
Both the LS6 and LS2 heads are 243 castings. The only difference is the valves they are equipped with and the valve springs. LS2 heads come with regular valves while the LS6 heads come with LS6 springs and the lighter valves like you mentioned. If you buy just the 243 heads (either LS6 or LS2), then buy a set of the lighter valves, and some good valve springs, you've got "an LS6 head".
