View Poll Results: Will my 10 bolt live?
It will survive!
28
42.42%
10 bolts belong in a dump
38
57.58%
Voters: 66. You may not vote on this poll
Poll: Will my 10 bolt survive?
I know the deal with 10 bolts, they are junk, my bother exploded his in his cammed M6. But how many of you think it will survive the following mods *edit* for 1 or 2 track seasons:
-3600 stall
-MT ET street radials
My car currently has 350rwhp with bolt-ons and im looking for the best 1/4 possible, (hopefully some low 12's) I will eventually go 12 bolt, but want to hold onto some $ $ $ now. I understand 10 bolts can and have broken on stock power, but im curious as to what you guys would do.
-3600 stall
Mine went before the the first oil change. Grenaded so bad had to get a new driveshaft and I will just replace the rearend. Lost it from 2nd gear on the street. My rear goes clank and vibrates ever rotation. M6 is like a type of explosive you use to blow open a 10 bolt.
Going on my 3rd 10 bolt rebuild. With a stock converter and M/T drag radials I got about 2 years and 120+ passes out of it.
Now I have a 3500 stall and worked 10bolt - I give it a year or so depending on the amount of passes I put before it goes.
The engine just has minor bolt-ons and before the converter I was running 12.5s
Would installing some LCA's help control wheel hop? These would swap with my eventual 12 bolt, so I still wouldn't be spending a dime on this piece of garbage. Also, im only looking to get 1-2 track seasons out of the 10 bolt.
Originally Posted by WFOSS
my bros lasted about 5 feet at the track (D.R.'s cam, sfc's, lca's, full bolt-ons in an A4 with a 100 shot spraying it off of the line, now he is going to a nine inch.
I would be staying bolt-ons only.
i think it will survive with a t/a cover. severla guys ive seen are running low 10's with 1.5xx 60's (gm muscle being the first that comes to mind) on a 10 bolt. i wouldnt trust it though, and dont trust mine, hence why i bought a platinum aaa membership, and am going to pick up my spare 10 bolt saturday
ive been DD my 10 bolt car with Heads/cam/ 90/90, drag radials, M6, suspension stuff for a while. its all how u drive the car. so far its handled the abuse fine (knock on wood).. and i couldnt see a T/A cover making ur 10 bolt any stronger.. and ill let u know how the 10 bolt does when i get my direct port up and running here in the next few weeks
Originally Posted by Black Plague
Get the LG girdle cover & stud kit! And maybe even some vinci mikronite prcocessed gears..
