Drag Racing Tech - PA Racing Manual rack???
slowredz
03-22-2007, 03:24 PM
Anybody used it? How is the steering?
Billy the Great
03-22-2007, 03:43 PM
unless it is a kit designed to bolt onto a 4th gen then i would just get the Madman setup. Had a buddy try to use a generic rack and it ended up costing him way more than what Madmans kit goes for. Sure the rack itself is cheap but its all the little stuff that adds up and kills the savings
JMHO
slowredz
03-22-2007, 06:39 PM
It is a kit made specifically for F Bodies.
skipperbisket
03-22-2007, 07:49 PM
Josh, I would assume it is fairly similar to a Madman rack in which case as long as you're running skinnies up front you're fine. What is the cost of the PA setup?
This is my Madman rack using some "custom" mounts rather than what comes in his kit. Also, his setup comes with the right steering shaft to just bolt right in, drill one hole and you're ready to go, just make sure you clarify when you order (if you did go that route) that it is an LS1 car as the shaft differs from an LT1 car.
http://img.photobucket.com/albums/v203/slowverado/IMG_02952.jpg
slowredz
03-23-2007, 01:05 AM
The PA is almost $200 cheaper for their kit...
ATwelveSec02Z28
03-25-2007, 10:02 AM
I have the PA Racing K-member with Pinto style mounts, and the manual rack. The kit is pretty good but getting the geometry straight can be a pain. As far as I know PA is not making a setup like MadMan where it mounts to the OEM mounting locations.
cainsw
03-25-2007, 04:37 PM
How big of a deal is it to put one of these on and get it set up right? I'm refering to the Madman setup
ninetres
03-25-2007, 08:18 PM
I will let you guys know. I am having one installed in a week or two. Hope it isn't that much of a PITA.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
