Dynamometer Results & Comparisons - what happened to the beck intake and et 245 thread
ls1nos
03-22-2007, 03:28 PM
I was very interested in results
jrp
03-22-2007, 03:39 PM
deleted by the thread user
pewter 01 SS
03-22-2007, 09:48 PM
damn that sux, i was looking in here everyday to see what gains he got.. that sux Im interested in the intake but not sure if its worth the money.. anybody know if he ever got it dynod? Last thing i read was that it was getting sd tune today or tmrw??
ONEBADWS6
03-23-2007, 12:46 PM
Sounds fishy to me that it gets deleated before the results are posted. I know where I won't be spending my money.
beardWS6
03-23-2007, 01:43 PM
I posted in your other thread. I have issues with my tranny right now! But I will tell you this, you have to pull from 7-8k for this intake to be worth it. I can`t right now and that sucks! :(
Patrick G
03-23-2007, 01:44 PM
From what I heard, the initial runs showed the setup gaining something like 40-50 rwhp at 7000 rpm and was still climbing. I don't think the final configuration is complete. Patience.
santiago
03-23-2007, 03:23 PM
so wut about from 2500-6500??
Patrick G
03-23-2007, 03:27 PM
so wut about from 2500-6500??Sheet metal intake and 2500-6500 rpm don't go together. That's where the FAST intake shines. A sheet metal intake shines in the 6000-8000 rpm range. If that's not you're power band, stick with a more street-oriented intake.
71CamaroLS1
03-23-2007, 03:58 PM
Just to be clear, it's not the fact that it's a sheet metal intake per se - it's the runner design (length, cross section, taper) which determines the RPM range where an intake will "tune in" (take advantage of finite amplitude waves to augment volumetric efficiency). The most simple sheet metal designs that fit under the hood of an f-body will have short runners, and thus favor high RPM, but this doesn't necessarily have to be the case - see the Wilson LS7 sheet metal intake, for instance, which cleverly packages in longer runners.
BTW, it's possible to have runners so short that you never get real finite amplitude tuning effect at all in the operating range of the engine - the Gen 2 LT1 intake is an example.
Patrick G
03-23-2007, 04:03 PM
BTW, it's possible to have runners so short that you never get real finite amplitude tuning effect at all in the operating range of the engine - the Gen 2 LT1 intake is an example.:werd: Very true. Thanks for clarifying my statement. :)
beardWS6
03-23-2007, 04:07 PM
Thanks guys. I talk with Joe. He really said I need to shift atleast 7k. I`m going to drive it when I pick her up and see how she does. I`m going to take her to the track and she how she runs. Might run her ass off for all I know!! Joe said on spray she was really making good power. We shall see! If not, someone will save some money on a sheetmetal intake if they want to. My wife said no more money for a tranny :( ! Might have to sell and get another intake set-up, maybe a Victor. Who knows! this thing does make power up top though I just can`t get to it :bang: If I only had a 6sp
kcmags
03-23-2007, 04:09 PM
I'll let you guys know in a few weeks how it works with 14lbs of boost.
71CamaroLS1
03-23-2007, 04:31 PM
Boost is a completely different story. The effect on engine breathing of 14psi pressure differential almost completely overwhelms the effect of finite amplitude waves. You'll notice that N/A Pro Stockers have very carefully constructed sheet metal intakes with distinct runners, but a Roots blower drag car just pumps air from blower to intake port in the shortest possible path.
santiago
03-23-2007, 05:46 PM
im jus gonna use my fast then
beardWS6
03-23-2007, 05:49 PM
Your sig says Beck! Joe told me when the car starts pulling 5k it starts to run its ASS off! This was while he was SD tuning it!
santiago
03-23-2007, 07:12 PM
it says that cuz thats what i was planning on running. i have no motor right now cuz its being built.
Quik
03-23-2007, 07:45 PM
shows a sheet metal intake isnt for a street car!! and since when do you need to shift high on a dyno when making a 4th gear dyno pull?
2200 down the drain
beardWS6
03-23-2007, 08:37 PM
2200 down the drain[/QUOTE]
I guess everyone has there own opinion. Sorry you feel that way!
ls1408cp
03-23-2007, 09:07 PM
I would just like to see the dyno graph layed over your fast90 graph
Quik
03-23-2007, 09:11 PM
yes it would be nice to seethe dyno chart on it.
ls1408cp
03-25-2007, 01:15 PM
so are we not going to get a dyno graph? I guess I will be keeping my et245s stock.
ls1408cp
03-25-2007, 01:55 PM
what is the runner length and weight of this intake?
beardWS6
03-25-2007, 01:56 PM
Dude, I`ve told you I don`t even have the car yet or dyno sheets. Give me a break. I`ve worked everyday for the past month and I start nights tonight for the next 4 days. I will pick up Thursday. Chill :bang:
ls1408cp
03-25-2007, 03:25 PM
you just told me congrats
