What size bulbs in gauge cluster?
leds can burn out and they can be replaced. there is a sponsor on her you can get them from. i cant remeber the name cause i have ever dealed with them. they sell them and other colored ones incase you wanna change the color
Not sure if you got this figured out but the gauge cluster uses 194 bulbs not LEDs. However it is possibel to replace the stock bulbs with leds but our Pontiac gauge overlays have a red film on them so changing the color is a little more complicated than just changing the bulb color.
Also, 1/4 turn to remove, no need to break out the soldering iron
I have no idea about other years but on 99s there are 5 194 bulbs that light the gauges and are held in place by 1/4 turn fasteners. There are 3 more bulbs, one each for the turn signals and one for the high beam indicator for a total of 8 bulbs. The leds that are behind the gauges are for the Idiot lights. Atleast this is how my 99 is set up and I'm sure there are some differences between the years.
