Where to purchase STOCK chrome or stainless lugs and locks?
Old 03-22-2007, 08:42 PM
_JB_'s Avatar
Default Where to purchase STOCK chrome or stainless lugs and locks?
I found out the other day the lugs that are on my car can not be removed with the jack handle thing. So that means if I got a flat tire I would have been SOL.
I know I need 3/4" hex acorn bulge lugs but I can't find any to buy. The only place I have found them is at Gorilia's website but I can't order from them. Could someone point me in the right direction?
I've tried Ws6store.com but the lugs they have are the stock lugs with plastic chrome covers, but also says you can't use them on WS6 rims. Tried afterthoughtsauto and the same thing. Tried ebay, can't find the right size. Thunderracing has a bunch, but I can't find any with 3/4" hex. Do I need the 12mmx1.5?
Old 03-22-2007, 09:30 PM
nevadadave's Avatar
Default wheels
I dont know if these will work for you but check them out. The lug wrench is pretty cool actually. At least for along side the road. When I had my bird that exact thing happened to me. I was fortunate with a passerby who happened to have a big set of vice grips. Although it scratched the rim and destroyed the lug nut I was able to get it loose.
http://www.westcoastcorvette.com/pc-...g-nut-pkg.aspx
http://www.westcoastcorvette.com/pc-...ut-wrench.aspx
These are the lugs that I actually use now. All 5 nuts are a lock its a pretty cool looking set up.
http://www.lgmotorsports.com/catalog...roducts_id=325
good luck
Old 03-22-2007, 09:32 PM
Ralls's Avatar
Your lugs must be on too tight then. Make sure they are 100 ft/lbs. I can take mine off with my 1/2 inch ratchet which is probably shorter than the jack handle.
Old 03-22-2007, 09:38 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Lightbulb
You should really get a torque wrench and a small extension..I did.
wvaboy's Avatar
ws6store has exactly what you're looking for.
is this not it?
http://www.ws6project.com/user_stor/...02b9ee12a26db4
Old 03-23-2007, 12:23 PM
_JB_'s Avatar
The lugs on my car now are 7/8" hex, while the stock lugs are 3/4" hex. It's not that I tightened them down to much, it's just the lugs are too big.
Old 03-23-2007, 12:24 PM
_JB_'s Avatar
No need for the tourqe wrench and extension, I have those. See above post.
Old 03-23-2007, 12:25 PM
_JB_'s Avatar
is this not it?
No locks.
Old 03-23-2007, 12:27 PM
_JB_'s Avatar
good luck
I saw those, but I don't want to spend $60 on them, at least for 02 WS6 rims. One lock per rim is good for me. The others you posted I'm not sure about.
Old 03-23-2007, 01:46 PM
Xsta Z 28's Avatar
Stock lugs are metric . . . 19 mm I beleive . . .
Old 03-23-2007, 03:04 PM
_JB_'s Avatar
19mm does work but 19mm, 3/4", I don't care I just want something that works with the stock jack.
Old 03-24-2007, 07:40 PM
wvaboy's Avatar
it's kind of like i said, i either don't understand the question, or your not looking at what i am.
locks
lugs
they used to sell a package of 20 locking gorilla lugs. didn't see those on the site, may want to call and ask.
Old 03-26-2007, 01:37 PM
_JB_'s Avatar
locks
lugs
Ah ok, I didn't see the locks. I'll give them a try! Thanks!
