415ci LS2 + 2800lb car + 87 Octane = ? Cam ?
I am planning to put a 415ci LS2 engine in my 1988 Pontiac Fiero that weighs only 2800lbs.
The car is my daily driver. I want good acceleration, good gas mileage, a smooth idle and good street manners. Max horsepower is not a major concern.
Most of my driving is in the 1,8000-4,500 rpm range. I知 looking for torque.
I also want the car to run on 87 octane gas.
What cam would work best for my application?
Thanks for your time and your input.
Bob R.
Bob R.
Camshaft valve events along with static compression will determine octane requirements. Well... along with quench, combusion chamber design, swirl etc..
Maybe 9.5:1 static. Not sure on DCR maybe 7?
Originally Posted by 81LsElky
umm im confused, cam does not really have an impact on octane, but i may be wrong, i thought it was compression! my .02
Bob R.
Bob R.
Bob R.
Bob R.
Bob R.
Bob R.
In a car this light, I'd choose a cam that flattens the torque curve a bit, while extending the RPM range - you will have enough terrifying experiences with 60 MPH wheelspin as it is. On a 5.7 or 6.0 motor, something in the range of 220 to 224 degrees intake duration @.050, with a lobe separation of at least 114 degrees, maybe 116, will give you a smooth idle, good torque and responsiveness in your desired RPM range, and still give you excellent high rev power when you're feeling immortal.
If your heart is really set on that 415, bump those cam specs up another 8 to 10 degrees, beef the hell out of your drivetrain, and make sure you experiment with full throttle in an environment with lots of room for error.
For reference, the '67 Camaro in my sig weighs 3400 lbs, and will spin it's rear tires (315s) at 100 MPH in third gear. Exciting as this sounds, in practice it means that the car's potential is mostly wasted on me, due to fear of death and other considerations. If this is really going to be your daily driver, think hard before you turn it into an experiment in extreme physics.
I'd suggest a worked ls1 which can be had relatively inexpensively..
I would not suggest running 87 octane fuel either..
What transmission are you using?
Sounds like a hell of a ride.
photos?
photos?
Thanks to all for the feedback.
Special thanks to: ringram, RWC, 71CamaroLS1, and JBsZ06, for all of your constructive comments and advice. It is greatly appreicated.
71CamaroLS1痴 comment about, "an experiment in extreme physics", has given me pause to think. Thank you sir.
While I知 far from being a kid, I still lack any experience with a car who痴 engine produced a significant amount of torque.
JBsZ06, I値l be running the stock Getrag HM-282 transaxle. Reliable sources tell me that it is capable of handling the power and torque of a V-8.
Once again thanks to all for your help.
Additional comments/info/advice would be greatly appreciated.
Bob R.
Bob R.
Race your car!
I think a 415 CI in a car that small... is probably not a good recipe for your needs. A stock ls2 shortblock with a set of lq9 heads and a cam in the low 220's would be enough to make that little car really fly, and with the reduced compression from the lq9 heads I suspect that 87 octane would be doable, as long as the timing is kept down. It would nowhere near be the optimal way to tune the motor, but for the goals you have a motor like that would probably scare you daily LOL.
