Adjustment Questions.
I'm new to the 4l60e I was wonderin if there's any band adjustments or anything to do while changing fluid.
And is the fluid/filter change pretty straight up like any other tranny?
LS1Tech Sponsor
There are no ajustments normally needed during a service of a 4l60e . I would sugest that provided the seal is soft and the filter fits tight that you do not attempt to change the gromet seal thats in the pump for the filter , Is a major pain under the car and should be fine
__________________
