Trans Shifting Earily Please Read And Help Asap
Old 03-23-2007, 08:48 PM
Jpr5690's Avatar
Default Trans Shifting Earily Please Read And Help Asap
OK WITH MY STOCK TRANNY AND REAR EVERYTHING WAS WORKING FINE
THEN THE SHOP INSTALLS A DANA 60 AND FLT LEV 4 TRANNY WITH VAC MOD... NOW
EVERYTHING SEEMS GOOD BUT THE CAR SHIFTS AT 4500 RPMS ... IF YOU PUT THE SELECTOR IN FIRST YOU CAN WIND OUT THE GEAR AND YOU CAN MAUNALLY SHIFT THE GEARS AT ANY RPMS BUT WHEN LEFT IN DRIVE THE CAR JUST SHIFTS AT 4500 FOR EVERY GEAR.....
THE SPEEDO SEEMS TO BE READING FINE AND NO CHANGES HAVE BEEN MADE TO THE PCM SINCE THE SWAP EVERYTHING SEEMS GOOD
MY ONLY PROBS ARE FROM ANY SPEED, EVEN FROM A DIG THE RPMS WONT GO OVER 4500.. YOU CAN TELL THAT WHEN YOU HIT THE GASS THE STALL FLASHES TO ABOUT 4000 ISH AND THEN ONLY 500 RPMS LATER THE ****** SHIFTS
ALSO WHEN CRUSING YOU SLAM ON THE THROTTLE FROM A ROLL AND THE CAR WONT DOWN SHIFT.. THE CONVERTER WILL UNLOCK BUT IT WONT DROP GEARS....
Old 03-23-2007, 08:57 PM
LS1Tech Sponsor
performabuilt's Avatar
Did you change the gear ratio in the rear, and or did you change the converter, If you did either your going to have to re tune for one or both ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-23-2007, 09:16 PM
Jpr5690's Avatar
Changed Converter But Only From A 3500 To A 3800 Rear Gears Is The Same Ratio
Old 03-23-2007, 09:17 PM
Jpr5690's Avatar
Im Thinking Faulty Tps Sensor?.. I Know They Were Messin With My Throttle Blade A Bit And Mabye It The Sensor Got Messed Up And Now The Car Wont See A High Tps ?
Old 03-23-2007, 09:30 PM
LS1Tech Sponsor
well tps is possible .You should be able to determine that with a scanner
__________________
Call 888-744-6542
Old 03-23-2007, 09:58 PM
Jpr5690's Avatar
Yea Its At A Shop.....so I Cant Scan It But Just Tring To Get An Idea..
Old 03-23-2007, 10:08 PM
Jpr5690's Avatar
Any Other Guesses Anyone?
Old 03-24-2007, 12:39 AM
Moderator
jimmyblue's Avatar
Shifting is supposed to be PCM controlled and I guess your
options are it's not being listened to, it's not commanding
or it's being lied to about TPS or MPH. TPS you can check
with a voltmeter. MPH and commanded actions you want
the scan tool. From there on out it's sparks and then
hydraulics. Suppose there's no chance the wrong kind of
VSS is on that new trans?
Old 03-24-2007, 05:31 AM
JEB99TA's Avatar
Saw your T/A up on the rack at the shop earlier this week ... looking real nice John. I changed gear ratio from 3.23's to 3.73's a few yeards back and mine acted the same way ... tuning issues ... hope you get it worked out soon.
Old 03-24-2007, 02:36 PM
Jpr5690's Avatar
I Dunno Mabye They Had The Wrong Gears In It.. But The Speedo Seemed Fine
Old 03-24-2007, 02:37 PM
Jpr5690's Avatar
Vss On New Trans ?
I Ca Ask Its Out At Nlp So Their Incharge Of Fixing It As Of Now But I Will Definately Give These Suggestions
Jpr5690's Avatar
Thanks Jeb!
Old 03-24-2007, 07:40 PM
Jpr5690's Avatar
Got It.. I Think They Improperly Adjusted My Throttle Cable
Old 03-24-2007, 08:36 PM
LS1Tech Sponsor
Well not going to WOT would keep you from having WOT shift points lol
__________________
Call 888-744-6542
Old 03-25-2007, 01:20 PM
Jpr5690's Avatar
Yea It Seems So Stupid But Hell Im Glad Its An Easy Fix
