Sponsored by: DashLynx
Put LED'S in DASH BUT they are not as bright as they should be????
Old 03-23-2007, 08:49 PM
bjamick's Avatar
Default Put LED'S in DASH BUT they are not as bright as they should be????
Ok i just finished putting all the LED's in my guage cluster but its not bright at all and im wondering what could i have possibly done wrong???
Old 03-23-2007, 08:53 PM
ICEMAN 31's Avatar
hmm any pics
Old 03-23-2007, 09:03 PM
bjamick's Avatar
ok this is a pic of the dash!! See how dark it is
Old 03-23-2007, 09:13 PM
DirtyBird222's Avatar
hmm, do you still have your trans am gauge cluster in there? If so that is your problem! The red film/filter they put on on the trans am instrument cluster will not lot all that much light shine through, if you use white leds it will make it look pink, if you use red the light will be dim. Switch to a camaro instrument cluster with leds and your problem should be fixed.
Old 03-23-2007, 09:17 PM
nomoneyz's Avatar
Dang thats dark. What kind of LEDs did you buy.
Old 03-24-2007, 12:18 AM
mycamaroSS's Avatar
that sucks dude......
Old 03-24-2007, 01:39 AM
bjamick's Avatar
They came from super bright LED's..
I took off the old black guage overlay bc i got the white one from speed inc. so i decided to go ahead and do it all at once. well once i got it in there and i turned it on i was disapointed . Not for sure what the problem is but i hope i can mess around with it some tomorrow.
Old 03-24-2007, 01:50 AM
bjamick's Avatar
Ok i took off the black part and put on the white part in its place.. SooOOo isn't that all thats needed?? I mean why wont the light shine through?
Old 03-24-2007, 02:23 AM
530transam's Avatar
so you put the white part down against the clear plastic piece? if this is what you did then the light should come through just fine. what color are they? are you sure they are the right watts/omhs? you should specify your using it in a vehicle gm more specifically to make sure everything complies.
Old 03-24-2007, 08:22 AM
01Z0H6's Avatar
Listen, with the LED's you could have to take them out and flip em... when you lock them in, the + should be + and the _ to _.. make sense?
Turn em 180deg...
Here, read this...
http://www.ledgauges.com/camaroinstructions.html
Good luck...
Old 03-24-2007, 09:25 AM
bjamick's Avatar
i was told i needed a camaro guage cluster. Is there no way i can make the TA one work?
Old 03-24-2007, 09:45 AM
01Z0H6's Avatar
hmmm... i just happen to have one...
PM me if interested...
Old 03-24-2007, 12:04 PM
prolly not and the 194 bulbs from superbrightleds are non polarized so you can have them in there anyway. I found the best to test this stuff, is take the actual gauges off the cluster. Put the cluster in then put the bulbs in to see if they come on in there nice and snug. Then put the gauges back on. I'm not the best at explaining things but if you need pictures of what I am talking about pm me!
Quick Reply: Put LED'S in DASH BUT they are not as bright as they should be????
