ls7 cam in ls1
Old 03-24-2007, 03:37 AM
Function>Form's Avatar
Default ls7 cam in ls1
the specs i believe are about 211/230 .590/.590 120 lsa
how would this run on a bolt on car with a ls7 valvetrain swap and full bolt ons/spray
Old 03-24-2007, 03:38 AM
Justin00SS's Avatar
I'm not sure it would work and an LS6 cam is cheap enough and would probably round up the same hp.
Old 03-24-2007, 08:34 AM
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
is the specs on the ls6 cam.
so the duration is much higher on the ls7 as well as lift and lobe seperation, but with such a big LSA im afraid i will only get power from 5k+
Old 03-25-2007, 02:55 PM
03 BUSA's Avatar
The ring for the cam position sensor is in the front of the motor on the LS7's so you would need atleast the extension harness and LS7 front cover. If this is what you really want I would just have Cam Motion custom grind you those specs on an LS1 grind. JMO
Old 03-26-2007, 01:53 AM
Bring the Noise's Avatar
Note 1: The LS7 uses a 1.8" rocker arm, LS6 uses a 1.7"
If the LS7 cam is placed into a LS1 with LS1 1.7" rockers the lift goes down to .557/.557. Thats is only slightly larger the then LS6 cam with slightly higher lift.
Note 2: The LS7 camshaft does not have a timing sensor on the cam shaft. The LS2 and LS7's have the sensor built into the timing sproket (part of the timing chain set). 03 BUSA Mentioned this as well.
Note 3: The LS7 Valve train will not completely transfer over to a LS1. Intake rocker arms for the LS7 are offset. Pushrods might not work as well as the LS7 is a 12 degree valve design and the ls1 is a 15 degree.
What will work, Lifters and exhaust rocker arms, springs, retainers, etc.
And that is one hell of a split for a 243 style head.
Old 03-26-2007, 06:12 PM
02silvaZ's Avatar
so using the intake rocker arms won't work? since the intake rocker arms are offset, are the exhaust rocker arms set up the same as LS1's? could the exhaust rocker arm work as intake rocker arms on a Ls1?
Old 03-26-2007, 07:48 PM
02silvaZ's Avatar
anyone chime in on my question please!
Old 03-26-2007, 08:19 PM
LS1 Tech Administrator
Patrick G's Avatar
That cam has an intake valve closing point WAY too late for a 346. Your dynamic compression will be very low and your peak power won't occur until way past 6300. In a nutshell, this cam's been tested in an LS1 more than once and people lost power every time. Run away, far away.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-26-2007, 09:22 PM
03 BUSA's Avatar
There is your final answer. Patrick is the man.
Old 03-27-2007, 05:05 AM
02silvaZ's Avatar
does anyone have any answers to my rocker arm question?
Old 03-27-2007, 07:55 AM
scatillac's Avatar
Default 02SilvaZ
Neither of the LS7 rockers will work on non-LS7 heads because a combination of the rocker ratio and valve angle.
To get the 1.8 ratio, you'll need an aftermarket rocker.
Old 03-27-2007, 02:21 PM
02silvaZ's Avatar
thank you scatillac
Old 03-30-2007, 03:15 AM
LSGunZ28's Avatar
are you sure 120 LSA?
Quick Reply: ls7 cam in ls1
