drain plug on 4l60e tranny
Old 03-25-2007, 01:36 AM
DisturbingDaPeaze's Avatar
Default drain plug on 4l60e tranny
that i seen/know/read/heard there is no drain plug correcT?
can i just buy one locally and drill and put one?
for those who have, give details where you got your plug and pics if possilble please!!
can i drill on the bottom of the pan? or has to be the side?
Old 03-25-2007, 10:10 AM
Moderator
jimmyblue's Avatar
Used '02 Silverado pan (+/- a year or two, they quit putting
drain plugs on some time later).
I think there are add-a-bung kits but nothing like original
equipment. Plus you can run the deeper filter.
Old 03-25-2007, 10:29 AM
GMRACER13's Avatar
Or buy an aftermarket deep aluminum pan. Most have a drain plug in 'em and you get a couple extra quarts of fluid.
Old 03-25-2007, 07:27 PM
chrs1313's Avatar
got a universal drain plug from pep boys...drilled the hole used the supplied washers and plug and you are good to go...
Old 03-25-2007, 07:52 PM
NHRAFORMULA00's Avatar
on the bottom of pan
Quick Reply: drain plug on 4l60e tranny
