Best heads for the money??
Old 03-25-2007, 11:46 AM
1mofbody's Avatar
Default Best heads for the money??
Wondering what would be the best heads for the money with a stock ci ls1 with big cam, spray, and vic jr intake? Any help is appriciated guys. Thanks
Old 03-25-2007, 12:16 PM
PREDATOR-Z's Avatar
ETP 215, Trick Flow or AFR 205
Old 03-25-2007, 01:30 PM
Studytime's Avatar
For the money, my opinion is Dart 205s can't be beat for the budget minded ppl who want big power.
Ben T.
Old 03-25-2007, 09:58 PM
Sigforty's Avatar
Dart heads definitely make some good power for the money.
Old 03-25-2007, 11:40 PM
cantdrv65's Avatar
Bang for buck: TSP CNCd LS6 castings....all out best head: Trickflows.
Old 03-26-2007, 12:32 AM
1320 killer's Avatar
call richard at west coast cylinder heads. He is a sponsor here. he does great work and def. knows what he is talking about.
Old 03-26-2007, 08:43 AM
ProjecT 9's Avatar
+1 Trickflow 215cc heads are laying down GOOD power.
Old 03-27-2007, 10:53 PM
1mofbody's Avatar
Thanks for the replies.....im still looking, but TSP's PRC ls6 cnc'd heads are looking like the best deal.....complete with patriot golds for $1095.00. How much power should I gain to the wheels with a good tune?
Old 03-27-2007, 11:28 PM
Hennytime's Avatar
trick flows seem to make the biggest hp and tq from what ive seen on well set up motors, vengeance is kicking some *** with those heads, hell some of theri builds make me ask if its a 383 or 402
Old 03-27-2007, 11:31 PM
cantdrv65's Avatar
Post
My Z06 gained 25rwhp and power and torque across the RPM range....From ONLY a head change(PRC Ls6), same cam, stock compression(no milling and I already had Ls6 heads), stock valves and Ls6 intake. After adding a ported Fast 90/90 I gained another 15rwhp....
I'm at 450rwhp now through the exhaust.....with further tuning I expect more.
Old 03-27-2007, 11:38 PM
Chicago Crew UnderBoss's Avatar
Who has these bad boys in stock and has the best pricing on them!
Old 03-28-2007, 03:48 AM
cowboysfan's Avatar
have u looked into stage II Patriot heads? give it a look. I'm making 418rwhp/389rwtq with stock block, LS6 intake, ported TB. kooks lt's, td's dumped, 231/237 112+4 . that is all. so imagine with 90/90 setup and underdrive pully.mmmmmmmmm!!!
fuerzaws6
Old 03-28-2007, 09:35 AM
eamador11's Avatar
AFR 205s..you get every dollar back in performance. True direct bolt ons, no hidden items to replace.
Old 03-28-2007, 09:47 AM
1997bird's Avatar
I am partial to the ETP 225's!!!
Old 03-28-2007, 09:52 AM
hpls1's Avatar
how much are the AFR 205's?
Old 03-28-2007, 10:05 AM
deejaydaze's Avatar
$2275.00
http://thunderracing.com/catalog/?ac...vid=3&pcid=114
$2,182.00 (free sh) was $2,350.00
http://texas-speed.com/shop/category...MID=1&catid=40
Old 03-28-2007, 10:09 AM
sciff5's Avatar
wow thats pretty impressive.. CNC porting kicks ***
Old 03-28-2007, 10:34 AM
BOWTIE's Avatar
Well I think the best head for the money is the TSP/PRC stage 2.5 5.3's, which is why I bought them. However, you mention N2O in your requirement which generally indicates the desire to go with something with a thicker deck for less chance of loosing the head gasket when ingesting larger doses of gas. One option to consider would be the Terminator heads which went for around $1800.00 the last time I checked. These are cnc'd from the Edelbrock castings so they have the thicker decks that you can only get from the aftermarket castings. That said I would most likely opt for the TFS's if I was going to spend that amount of cash anyway. Just be aware that with the TFS heads you will also need aftermarket rockers as well.
Old 03-28-2007, 10:49 AM
pushinfreight's Avatar
match your heads to your cam choice. just because you buy the best heads does not mean you have the best combination. also are you going to just race the car or will you see time on the street? dont get caught up in hype of these are the "best" parts
Old 03-28-2007, 11:58 AM
Studytime's Avatar
That's similar to what a local guy picked up swapping on a set of Dart 205s, but he picked up 29rwhp. That was with a 205cc intake runner VS. a 237cc intake runner.
Ben T.
