Heads/Cam package - Your thoughts
Old 03-25-2007, 03:21 PM
Pipelayaz's Avatar
Default Heads/Cam package - Your thoughts
I want your opinion on my setup I'm thinking about.
- Magic Stick V.4 239/242, .649"/.609" Camshaft w/lobe seperation of 111.
- AFR 205cc Mongoose heads with a 66cc chamber.
- And of course all the supporting mods and what not.
- Possably deck the head as well to increase compression? Not sure about this one.
Should sound pretty bad *** with my headers/X-Pipe ad other bolt ons.
-From what I been hearing I'm going to have to flycut the pistons as well. Whats the pros and cons of flycutting your pistons?
I have also been looking at the a "less agressive" Magic Stick V.3 237/242 .603/.609" w/lobe seperation at 112.
Would this be considered a good street/strip setup?
Old 03-25-2007, 03:39 PM
98SS2836's Avatar
Fly cutting depends how much milling your going to do to the heads. I would look at a G5x4 and only milling a little or vengeance racing vindicator which seems to work very good with lower compression motors should not have to flycut either.
Old 03-25-2007, 03:53 PM
brad8266's Avatar
If youre replaceing the heads then flycut the pistons about .100 no doubt dont even consider not doing it. That way you can get away with a smaller head gasket and a head mill both of which will bump up the compression. I would run a .040 gasket
After you flycut the pistons perform a PTVC test too see how much room you have to work with to mill the heads and mill them as far as you can to get to PTVC of .080 intake/.100 exhaust.
Do not dare mill the heads unitl you check your PTVC!!
Old 03-25-2007, 06:41 PM
Pipelayaz's Avatar
Thanks for the info fellas... ttt
Old 03-25-2007, 06:45 PM
ls2 bait's Avatar
i think with that cam u may be better off with a tfs head. those afr heads seem to like a tad smaller cam from what ive seen so u can mill them to bump the cr without having to notch the pistons.
Old 03-25-2007, 07:30 PM
30th t/a's Avatar
I know my AFR's love my G5X4. I think the combo you listed would be really good.
Old 03-26-2007, 06:10 AM
98SS2836's Avatar
Are you head milled at all? or did you flycut this pistons?
Old 03-28-2007, 05:40 PM
30th t/a's Avatar
the heads are milled to 59cc and the bottom end is forged with notched out pistons.
going by your sig, I see you picked up a few more ponies
what did you do to your setup?
Old 03-28-2007, 07:06 PM
98SS2836's Avatar
I went over my dyno graphs I have a **** load Because one of my buddies has a dyno I found one that had those numbers corrected. It was one of the runs that I did uncorrected. I usually average the numbers and put them up one my sig. the old numbers were an average of ten runs these are just on single run. I did pick up more with my ported fast and stepped headers but the new 4.30s may dwell on them a bit. Car is a whole different animal with those gears. The cam is made for them.
Sorry about the hi jack.
