Lingenfilter Gt2-3 cam??
Old 03-25-2007, 03:27 PM
blackfbird's Avatar
Default Lingenfilter Gt2-3 cam??
Looking for a cam that is streetable, basiclly idle stock. Is this a good cam to go with and what hp gains will I see?
Old 03-25-2007, 03:46 PM
NviouSS's Avatar
it idles just like stock so to the untraind ear you won't be able to tell it's in there. with stock manifolds i picked up 30 rwhp and another 15 rwhp after adding longtubes. i recommend using 918's with this cam.
Old 03-25-2007, 03:49 PM
brad8266's Avatar
That cam is a sleeper cam all the way, it idles the same as stock, the only giveaway would be the bit of extra valetrain noise from the high lift.
Old 03-25-2007, 03:57 PM
Rob
Rob's Avatar
I had absolutely no valvetrain noise at all. Mine was as stock sounding as stock
Nobody believed I put a cam in the car so I just stopped saying it. I used the LS6 springs the kit came with and had no problems at all.
Old 03-25-2007, 04:10 PM
brad8266's Avatar
With LS6 spring it wont have valetrain noise, with some comps or something like that i would imagine it would be a bit noiser.
Old 04-06-2007, 03:00 PM
Cahill93Z28's Avatar
is there any performance benefit by using comps over LS6 springs?
Old 04-06-2007, 03:15 PM
transamfreak01's Avatar
how does this cam compare to the stealth II cam???
Old 04-06-2007, 03:49 PM
NviouSS's Avatar
not really.
Old 04-06-2007, 05:03 PM
2002/Black/SS's Avatar
my lingenfelter gt-7 is the same as stock. literally barely any change. and its bigger then the gt2-3
Old 04-06-2007, 05:22 PM
Daredevil_TA's Avatar
what about with patriot golds?
Old 05-22-2007, 05:21 AM
Pimpium57's Avatar
Curious as well.....would the Stealth II or GT2-3 work better with stock manifolds?
Old 05-22-2007, 05:36 AM
PREDATOR-Z's Avatar
GT2-3 works better with stock manifolds (it is designed for that).
Stealth II requires good freeflow system
