F13 (230/232) 110lsa
Old 03-25-2007, 05:08 PM
ProjecT 9's Avatar
Default F13 (230/232) 110lsa
anyone running this specific cam? i have Allan grinding me a High Lift F13 with a 110LSA, I'm just wanting to see some graphs and results with this specifc cam. thanks in advance. I've searched and didn't come up with anything, just one guy with a sound clip.
I'll be running:
LS6 intake
TEA 1.5 5.3 heads (61cc)
.040 MLS Cometic
High Lift F13 110LSA (230/232 .642.612 110LSA;110ICL)
Adjustable Timing chain
Flycut pistons .080
1 3/4 LT, ORY, Hooker CB
SCR 11.44:1, DCR 8.66:1
I'm looking forward to the new changes, should be a stout setup.
Jon
Old 03-25-2007, 05:54 PM
dug
dug's Avatar
looks good on paper. What kinda power you expecting? 450rwhp?
Old 03-25-2007, 06:00 PM
3.8to6.0's Avatar
Looks like a good combo. I am thinking about running Futral's new highlift F14 on a 112lsa with a set of TEA 1.5 LS6s. Keep us posted.
Old 03-25-2007, 07:24 PM
ProjecT 9's Avatar
450 would be nice, i guess you can say that is my goal. I'm just looking for a good street setup that will make good power. what i want the most is to change my power range to one more usable. with the F14 i had, it was 3000-7000rpm and i just didn't operate in that range or spin my motor that high. I wanted a cam in the range of 2300-6600rpm to suit my driving style and one that could also make big power if setup right.
Jon
Old 03-26-2007, 08:10 AM
ProjecT 9's Avatar
well the more and more i search i cant find anyone running the cam. so I'll post back when I'm done.
Old 03-26-2007, 09:49 AM
SOMe WS6's Avatar
i am running an F13 114lsa and prc ls6 heads. it is a pretty nice setup. still waiting for some numbers since putting the heads on.
Old 03-26-2007, 10:58 AM
ProjecT 9's Avatar
so the 401 rwhp 380 rwtq is cam only I'm assuming? I'm specifically looking for someone running the cam with a 110lsa and high lift. I'm sure someone has it, they just dont post on here often or at all. good luck with setup man.
Jon
Old 03-26-2007, 11:53 AM
dug
dug's Avatar
do the intake ports flow good at high lift?
Old 03-26-2007, 12:33 PM
PunkNPonys's Avatar
Just out of curosity why did you decide to go with the highlift F13 vs the old F13? If you want the RPM range to be lower i would think you would want a lower lift but i could be wrong on that. I dont think there is going to be much hp difference from the two, so why go with the higher lift? The only reason why i am asking because i thought about switching to the highlift F13 also.
Old 03-26-2007, 01:26 PM
ProjecT 9's Avatar
318.3 @ .650
Old 03-26-2007, 01:54 PM
ProjecT 9's Avatar
well basically I'm just wanting to try it out. i have some heads that flow decent at .650 and theoretically having the cam on a 110 lsa and advancing it 2 degree's with my timing chain gives me valve events to make power in the range i want. i went with the high lift version to maybe get 10-15 more rear wheel out of it. maybe i wont get it, but im willing to try. ill be restricted by my intake, but i plan on swapping over to a 90/90 in about 5 months, and i should see better gains then, obviously b/c I'll be getting more air in to take advantage of the .642" lift.
Old 03-26-2007, 01:56 PM
PunkNPonys's Avatar
What kind of numbers did you put down with the F14?
Old 03-26-2007, 02:18 PM
ProjecT 9's Avatar
442rwhp @ 6800
402rwtq @ 4900-5000
SCR 10.8:1
DCR 8.12:1
Old 03-26-2007, 02:24 PM
Sharpe's Avatar
Hope you're tuner is ready for that job.
Old 03-26-2007, 02:29 PM
PunkNPonys's Avatar
442rwhp @ 6800
402rwtq @ 4900-5000
SCR 10.8:1
DCR 8.12:1
Those are pretty stout numbers. But i hear you when you say you want to lower the power band. I dont see any need to spin the motor to 7000rpm in order to make power. I think your new combo will be killer. Well keep us updated. Goodluck.
Old 03-26-2007, 02:30 PM
ProjecT 9's Avatar
I'm sure he'll be fine..
Old 03-26-2007, 02:44 PM
algws6's Avatar
is it going to have enough P/V clearance?
Old 03-26-2007, 02:47 PM
ProjecT 9's Avatar
thanks man, ill be sure to come back and post how it runs. like i said, all I'm trying to achieve is a power band tailored to how i drive and better throttle response. I'm sure ill get it out of this setup.
Jon
Old 03-26-2007, 02:57 PM
ProjecT 9's Avatar
that's something I'm going to have to check, I've been told its fine on a 112-114 but being on a 110 lsa i want to double check.
Old 03-26-2007, 03:01 PM
Sharpe's Avatar
Your car has iForged Aero's? Where are da pics, man?
Quick Reply: F13 (230/232) 110lsa
