Code p0420
Code p0420
code p0420 catylist efficiency low bank one
is it cat or the o2 sensor didnt lookinto it yet code came one today braught it to my shop and im gonna look at it tomarrow but have you had any experiance with this or weich problem it is?
Originally Posted by 03 BUSA
Bank one is the left side. That code is usually for the o2 sensor, not the cat. Again that is in most cases I have seen.
WS SIKZ,
If you fall under the 8yr/80k, take it to the dealership and tell them you think it's a cat problem. They will diagnose it, verifiy its the cat, and order you one. Hell if its a pontiac dealership they may have one in stock.
-Josh
P0420 is a bad driver's side cat. I had this code right after I got the car last Summer before the LT install. Went to the dealer, they scanned it and replaced the drivers side cat. Absolutely no charge.
Originally Posted by jason1384
I also got a P0420 and a P0430 code. If i take it to the dealership to be replaced and they scan it, do they charge you for the scan?
Originally Posted by 2001NBMZ28
Friend of mine had his drivers side replaced free under warranty - no charge for the scan if they diagnose the cat(s) as the problem. He didn't clear the code - left the SES on.
Same for me Drivers side. my car had about 30K miles at that time too.
