Is there a difference between the 97 lt1's valve spring caps &
the lt4's valve spring caps... reason i ask is because i change valve springs and only recieved 8 caps... anyway i used calipers and measured the lt1 and lt4 caps and they were identical...
i have an lt1/lt4 rebuild book and the only cap part #'s it calls out are for 93-96 regular and lightwieght caps for aluminum heads and lt4 lightwieght caps...
did not mention a part number for the 97 lt1's...
does anyone know if they are different?
