DFCO minimum TPS% ??? (HPTuners)
I must not be reading this right???
"DFCO Enable TPS vs. RPM: Throttle position must be below this table value"
(See attached pic.)
The way I read this, the TPS must be below these values (at given rpm) in order to enter DFCO..., right???
My TPS is never this low, how is this working???
Any help appreciated...
(See attached pic.)
Originally Posted by Rob
Didn't think DFCO worked on the 'Vette. Thought that's what I read but I might not be remembering right.
Needs to finish car
You need to look at the throttle pedal position, that should go down to 0 when you let off the gas. Actual throttle position never drops to 0 in my LS2 GTO either, but i know that DFCO works. You can see when the DFCO works by looking at the mileage calculator in the DIC or by longing injector pulse widths. The pulse widths in my car on drop to about 1.3 msec, as the PCM commands a minimum pulse width based on another table.
It is interesting to see the difference between pedal position and TPS, too. It'll make you wonder how much the car is driving itself.
My question is: how does the table mentioned in first post work... Even when DFCO is active I still see TPS of 5%...
Needs to finish car
There is an ETC pedal position PID under Engine->General tabs. There are also several other PIDs that have to do with throttle position. These PIDs may not be active on your car, but I have logged pedal position on mine in the past. The table in the first post works off of pedal position. If the TPS (actual position of throttle blade) went to 0, there would be a very, very small amount of air flow, as the car as no IAC. GM probalbly made the throttle stay open so that there would be a smooth transition into running again when the throttle is pressed. Also, a fully closed throttle would slow the car very rapidly.
