FU_I_AM_UltraZ
03-26-2007, 10:40 AM
The car would run constant 11.1s on pumped 93. it has 3:73 gears w/ none limited slip posi. the top end has the best. brodix track 1 alum. heads and have 2.02 and 1.60 valves, edle. rpm air gap series port matched to the heads. the radiator is a griffen 3 or 4 rows (can't remember) and w/ a 160 t-stat the car never went over 200 degrees in rush hour traffic in the summers. bottom end needs to be redone again or if you have a short block of your own..
for suspension.. it has an AJE tub. k-member, UMI LCA and panhard bar. the sub-frame connectors(t-tops) are homemade. for shocks, it has the kyb adj. AGX all around. tranny and rear are were build very STRONG. they've outlasted the motor twice already and the car had an est. of 520rwhp.
i've got another toy and also have a daily driver that i want to upgrade. I have a ton invested in this car and am just tried of it.
I don't have a set price for the car, but would consider reasonable offers and trades.
Thanks
-Charlie
Thanks
-Charlie
