Is a .030 head shave and this cam ok?
Old 03-26-2007, 10:59 AM
LS1 powered's Avatar
Default Is a .030 head shave and this cam ok?
The cam is a small 221/221 114. I'm wondering if taking .030 off the heads will be ok. The rest of the valve train is all stock length rods, and such.
Valves won't hit pistons, right?
Old 03-26-2007, 11:40 AM
GDM Z28's Avatar
i had .030 shaved off my heads and i ran a 226/585/112LSA cam
GDM Z28's Avatar
double post
Old 03-26-2007, 11:50 AM
Sounds good. Thanks.
Old 03-26-2007, 11:57 AM
GDM Z28's Avatar
no prob
Old 03-26-2007, 12:37 PM
BAD2000TA's Avatar
Just check your push-rod length. Do a search. There's a quick calculator to determine the proper length. Look under camshaft information, I think.
Old 03-26-2007, 01:35 PM
brad8266's Avatar
7.4 pushrods will probably be ok with that setup since there is .030 decked off the heads.
