lug nuts
Old 03-26-2007, 01:00 PM
chevygirl's Avatar
Default lug nuts and amount of torque specs
What amount of torque do you guys use on your factory 17in wheels?
Can I use the same lug nuts that came on my 5 star 16in rims on the car when I put the 17 in GM ZR1's on? Or do I need a different size or shape lug?Thanks for the answer on this guys!!
Old 03-26-2007, 03:12 PM
AnimalSS's Avatar
I believe the lugs on your 16 inchers are the standard factory lugs with the plastic "beauty" caps on top. I'm not sure if the ZR-1's are the same. If they're factory wheels, they probably are. You can always shoot an email to SLP and ask them, they're pretty good about replying.
Old 03-26-2007, 04:39 PM
Xsta Z 28's Avatar
Thay are the same . . . heck the lugs off of my 1993 Beretta GTZ fit my Camaro wheels.
A cone seat lug is a cone seat lug.
Old 03-27-2007, 12:11 PM
AnimalSS's Avatar
There you go.
Old 03-27-2007, 01:02 PM
JGKadell's Avatar
As long as they have the same thread pitch.
12x1.5
Old 03-27-2007, 02:56 PM
jond99's Avatar
100ft.lbs. of torque will do the trick.
