Best way to tune spark table
Old 03-26-2007, 07:34 PM
brad8266's Avatar
Default Best way to tune spark table
What is the best way to tune the spark table for all of the cells? I would imagine it being difficult to tune each cell and get it right. How does everyone else do it? I will be tuning my 232/236 112 cam with 57cc heads and any pointers on how to get the spark table real good would be helpful.
I was thinking increase unitl it knocks but there are so many cells that would take forver. Or should i just increase the entire spark table by a lot so I get knock retard in all cells and then just decrese the cells by the amounf of knock retard i got?
Old 03-26-2007, 08:13 PM
nikon1999's Avatar
are you using hptuners? if so i would look at someones tune from the repository that has a simliar setup to yous and compare tables.. I'd start with theirs and play with it from that point
Old 03-26-2007, 08:29 PM
ZL1Killa's Avatar
don't increase a bunch and then get hell of a lot of KR....
typical 00' models i have seen runn between 24-28 degrees timing WOT in the upper areas. otherwise make sure it has smooth transitions.. you DO NOT want spikes
Old 03-26-2007, 08:49 PM
brad8266's Avatar
So with the cam is is just good to advance a few degrees in the entire table? I can easily do my WOT spark areas i am just morte concerned with the rest of the table.
Old 03-26-2007, 08:53 PM
Rhino79's Avatar
I would say you could add around 2-3 degrees on the entire table probably and definetly in the cruise area of the table.
Old 03-26-2007, 09:00 PM
brad8266's Avatar
I added like 4-5 degrees already in the 1600 rpm and below cells. Car doesnt surge either really runs good. I guess i will just add 4-5 degrees everywhere and see how it responds. If i see knock retard all over the place i will back it off a degree or 2 through the whole table.
Old 03-26-2007, 09:03 PM
cantdrv65's Avatar
Post
I just smoothed and increased the entire table by like 3 degrees. I have to different dyno tests going from stock and then the three degrees. No difference in power whatsoever.....I've talked to quite a few high volume tuners adding advance to the stock table isn't going to make much difference. In fact add too much and you will lose power. I think mine lost power when I tried 29 degrees. I run 26.0 - 26.5 at WOT now....stock is 24.
Adding in the lower range does help streetablity though.
Old 03-26-2007, 09:06 PM
brad8266's Avatar
I am not looking from real power gains from messing with the timing, i am just looking to make it as nice on the strret as possible. Cams seem to like more spark advance.
Old 03-26-2007, 09:22 PM
brad8266's Avatar
My stock spark table looks like ***, all jagged. Should i smooth it all out?
Old 03-26-2007, 09:25 PM
Rhino79's Avatar
2-3 degrees was a conservative figure, I have tuned cars that cruise around 40-42* of timing, and they barely required any throttle effort, definetly helped the MPG too!
Old 03-27-2007, 05:57 AM
ringram's Avatar
You can log KR against the spark table and remove where it occurs. BUT, to do it properly you need to hit the dyno. I spent around 1 year working on spark, but 1hr on the dyno showed me the pointlessness of it all. Timing was up to 10* out from max tq in places.
Save your time and get fueling sorted then head to the dyno.
This is where a realtime solution works well. Get the dyno operator to load up the engine and hold it in a cell, then adjust timing until you get max tq, then move on.
efilive has a good tune tool and when used with roadrunner makes this easy. You can get the tune too to move to the active load cell and blend the area not just the cell. This makes the process easier and faster, as you can imagine. tuning each cell can take like 30sec-1min to zero in on pk tq. Just go in 1* increments, not like 0.1* or anything silly. I spent about 1.5hrs and did most part throttle cells and got loads more power.
Old 03-27-2007, 06:13 AM
brad8266's Avatar
My fueling already close, so i can quickly tune that in more.
And there isnt another way to do realtime without a roadrunner is there? realtime would be great but im not about to buy it just to tune spark.
Old 03-27-2007, 07:29 PM
Ragtop 99's Avatar
HPTuners has the ability to add/subtract in real time too. The downside is you need to remember what you did because the change doesn't get loaded permanently in the pcm until you adjust the table and upload the bin. I'd printout a grid with rpm and flow and then go through a sample of points using the method shown by ringman. Get off the dyno, load the changes and smooth it out.
Old 03-27-2007, 08:07 PM
brad8266's Avatar
Please explain the realtime process in HPT a little more if you dont mind, I was planning on getting HPT but I really like the realtime tuning capability of the RR with EFI Live. I am just split on what to get because I really like the very expensive one but I dont want to spend much money on tuning it, i am starting to get really cheap now that i put so much $$ into my car in the last few months with the new engine and all the goodies.
I havent been able to find much info on the realtime process in HPT so if you could just explain it a little more I would appreciate it. if i can make the realtime changes while in the middle of running the dyno and see how it reacts that is all I need, i can make note of what to do and make the permanent changes and reflash afterwards.
Old 03-27-2007, 08:27 PM
brad8266's Avatar
Nevermind i found a how to on the HPT site that shows the RTT process, and autotune will available on the next release too.
Old 03-27-2007, 08:48 PM
LS1Tech Sponsor
Slowhawk's Avatar
A safe bet is 2-3 degree's across the table.I've seen people crank timing way up and the headers started to glow at idle You can not tune low rpm/midrange of KR sensor's.Sometimes lugging it in 6th gear can help tune midrange nicely.
Old 03-28-2007, 01:15 AM
Moderator
jimmyblue's Avatar
Here's how I did mine a couple of years back.
First, you want to set up the knock retard to not
be so jumpy and to dissipate quicker. I think I cut
the attack by half and increased the decay 4X. It
just makes it not suppress so much of what you'll
be trying to find.
Now you do broad-envelope-driving, logging KR and
the CylAir and the usual suspects. Look at the spark
retard histogram max value. Anywhere it's 0 you add
2 degrees and anywhere it's nonzero you subtract one
to the HO timing table (and be sure you keep the LO
table synced up). Maybe you can find a cuter than
manual way to do this from the histograms. But manual
works.
Do it again. And again. Eventually you get to where
you are tickling KR all over the place. When you are
done playing, subtract 3 degrees from the HO and
maybe another 4 from that, to make the new LO.
You want to remember that this will all want another
looking-at, this summer when the pavement gets
toasty warm. But you might want to throw that
onto the temperature adders if you did the main
table tweaking at your "reference temperatures".
Old 03-28-2007, 07:45 AM
ringram's Avatar
Well while that method is better than just making up timing values, its never going to be the "best" method.
Old 03-28-2007, 12:49 PM
Moderator
jimmyblue's Avatar
Presuming "best" is hours on a load dyno (easy to find and
cheap to rent ).
From your experience of this sort what can you tell us about
the relation of MBT to onset of KR, presuming a normal-type
fueling and compression? All I've found is some rules-of-thumb,
best torque about 2 degrees before ping (hence my -3 final
adjustment from a +1 KR populated timing table). I would like
to know whether a "normal" LS1 follows this and whether the
non-WOT load-points respond the same as WOT, or if there
may be a higher spread at lower cylinder pressures etc.
Old 03-28-2007, 02:58 PM
BOTTLE ROCKET's Avatar
So WOT timing and cruise timing can be set differently? If so, how much timing are you generaly adding to the cruise timing?
Quick Reply: Best way to tune spark table
