Another fox body LS1 conversion
Hey guys,
I've been reading about these swaps for a couple months now. I have a decent turbo fox now, but I'm to the point where I'm going spend some cash to get the 302 reliable past the 500 hp mark. Just as you guys I'd assume to spend that money on an LS1.
I'm running a proturbo kit on a windsor based 302. I'm hoping I'll be able to change out the header flanges to the LS1 flanges and not have to modify the rest of the headers. I realize I'll end up modifing the cross over pipe and the intake tube. I suppose I will find out when it comes time to mock everything up.
The kit has PT64E turbo and I'm afraid it's going to be alittle small for the LS1's extra inches.
Fuel injection shouldn't be a problem, I'll have the BS3 swapped over to coil on plugs for the LS1 and integrate the 4l60E into the box.
Thanks for the research you've guys have already done... My current project and future mods can be seen at
www.turbojunk.com
zboss86
www.turbojunk.com
zboss86
very nice, but why a 4l60e??? too many guys break those tranny's even after they've spent $3000 to build them up.
My reasoning behind the 4l60E:
- I was going to get a engine/tranny combination "cheaper"
- I know it will be compatible with my BS3 Box
I'm currently researching the 4L80E's compability with John Meany's BS3 Box, and the physical/electrical differences of the 4L80E.
A properly built 4L60e will not break with 500hp, period. I know guys running mid 10s on 150 shot with them in heavy *** Camaros. Should be fine in your car, properly built of course.
Right, wrong, cool, uncool, i just can't believe you guys do this. I mean, you're going to catch hell from both the LS1 guys ("Why put such a great motor in such a shitty body?") and the Fox Body guys ("Why not have put a real motor in there?!"). You'll have no where to go without getting it.
he never said he was only looking at making 500hp, he just wants a block capable of handling more than that unlike the typical 5.0 block. who builds a turbo ls1 and only makes 500hp when you can come very close to that with a good head/cam/intake pkg.?
Sharpe....Right, wrong, cool, uncool, i just can't believe you guys do this. I mean, you're going to catch hell from both the LS1 guys ("Why put such a great motor in such a shitty body?") and the Fox Body guys ("Why not have put a real motor in there?!"). You'll have no where to go without getting it.
oh, and as far as the bs3.....if you've already got it and want to keep it and can modify it to work with the ls1 (not familiar with it), that's cool.
if not, why not run a stock pcm with something like efi live? a freind of mine has a twin turbo ls1 with twin 62-1's with 96lb injectors and making 850rwhp on pump gas only! just an option if you're familiar enough with programming that could save some dough.
LS1 powered foxbody?? whos stupid enough to do that!
as far as the 4l60e goes, i was gonna do a 6speed in my swap but decided to start off with the 4l60e and see how many i can blow up lol.
Transmission
My train of thought is:
-I'm going to need a converter either way
-4L80E should only be 20lbs heavier and it's in the center of the car
-There is only an approx. 15hp loss can be made up easily with the turbo
-I'm going to have to have a custom x-member and driveshaft anyway.
-BS3 is compatible with the 4L80E
I'm going to talk to my boyz at TCI and see what can be worked out...
