General LSX Automobile Discussion Non-technical LSX related topics.
Steel braided line ?
Old 03-27-2007, 03:20 AM
razorclaw99's Avatar
Default Steel braided line ?
my friend has an ls1 camaro. He has been having problems with the whole master cylinder, slave cylinder, all that good stuff. Basically its either very hard or cant get into gear. So after it was bled several times, it worked then stopped working. The problem was traced to the steel braided line having a leak which causes this problem to occur. Now we called up the dealer and he said that line only comes with a master cylinder, which of course we dont need. Is it possible to get that line separate?
Old 03-27-2007, 03:50 AM
EDS01SS's Avatar
you could probably have the line made if you have a shop in your area that does that kinda stuff
