2-3 WOT Flare
Old 03-27-2007, 04:23 AM
Ls1Envy's Avatar
Default 2-3 WOT Flare
Sometimes I'm getting a 2-3 WOT Flare. Anyone know the causes of these and a fix. Thanks.
Old 03-27-2007, 09:29 AM
LS1Tech Sponsor
performabuilt's Avatar
A 2-3 flare or rev bump happens when the band releases before the 3-4 pack can engage , They are supposed to nesarly overlap else during the shift you will get a momentary nuetral like feeling actually its a return to first,
This could be caused by a sticky check ball if its intermintant , other possibilities are excesive 3-4 clutch clearance. But basically you need to find a way to either turn the 3-4 clutch on faster or slow the release of the band, This was a very comon problem with the 700R4 but you dont here about it much with the 4L60E do you know what shift kit if any was used in your build?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-27-2007, 01:53 PM
Ls1Envy's Avatar
It was a custom shift kit with a new plate pre-drilled. A bigger boost valve was put in along with a stiffer 1-2 spring.
Rich wanted to go in and drill the hole out bigger. How big can you go on the hole before you get adverse effects?
Old 03-27-2007, 02:59 PM
LS1Tech Sponsor
Well the 3-4 apply you can go very big but what Im afraid of is the 3rd acum hole is already to big , That will cause the flare shift you are speaking of since the 3rd acumm is the back side of the servo and its what turns the band off.
__________________
Call 888-744-6542
Old 03-28-2007, 04:18 AM
Ls1Envy's Avatar
I guess the nexst step is pulling the pan and taking a look.
