ICS Head gaskets
Old 03-27-2007, 04:19 PM
stevieturbo's Avatar
Default ICS Head gaskets
Anyone using them ?
http://www.scegaskets.com/products/ics.html
I think my GM MLS are starting to weep a little, so will be doing a replacement soon.
ive ordered a pair of these. Copper based, 0.040" thick, with the steel ring etc
Stock bore, Stock LS6 block with the Edelbrock heads and ARP studs.
Will post pics when they arrive....
They did say they had some initial problems with early versions, but latest ones are working fine.
Old 03-28-2007, 09:23 PM
DAVESS02's Avatar
I've been using these for 6 mos. without a problem on Dart heads. Switching to
AFR's possibly this weekend and re-using these gaskets. They cost me about $200 with shipping from JEGs.
Old 03-28-2007, 09:49 PM
Tiago's Avatar
has anyone had good results with these? all of the ones Ive had contact with didn't hold for ****.
Old 03-29-2007, 01:49 PM
Mine arrived yesterday, will take pics as soon as I get time.
One thing that will annoy...it says you MUST re-torque them after running the engine to normal operating temp for the first time.
Old 03-29-2007, 02:51 PM
Roadie's Avatar
i'm running them... and yes, you do need to re-torque them after a heat cycle -- big PITA. It doesn't necessarily have to be after the first heat cycle, but definitely do it before you get into boost.
Regardless of what they say, use copper spray on them. It's also not a bad idea to throw a bottle of alumaseal in your radiator. Several people have not had the same luck sealing the water passages.
Mine sealed up fine with copper spray and no alumaseal...
Old 03-29-2007, 03:51 PM
pics....
you can almost see the stainless ring inside the C-section of the gasket, which forms the seal.
Old 03-29-2007, 07:34 PM
What exactly is copper spray ? Some sort of sealer ?
Old 03-29-2007, 10:39 PM
Roadie's Avatar
http://store.summitracing.com/partde...?part=vht-sp21
it fills any minor imperfections with copper and helps seal the gasket to the block and head surfaces.
Old 03-30-2007, 11:49 AM
Any other similar products ? Cant air mail aerosols, and one UK supplier that lists it is out of stock.
Old 03-30-2007, 12:07 PM
kp
kp's Avatar
http://www.permatex.com/products/aut...ve_Sealant.htm
pretty sure they sell permatex in the UK.
Old 03-30-2007, 02:09 PM
Roadie's Avatar
yeah... i actually have the permatex stuff. I just did a quick search to find some and picked the first summit racing link.
Old 03-30-2007, 05:54 PM
2kredss's Avatar
who makes these coopler gaskets??
Old 03-30-2007, 06:14 PM
see my first post.
Quick Reply: ICS Head gaskets
