codes p0102 and p0122?
Old 03-27-2007, 06:03 PM
senicalj4579's Avatar
Default codes p0102 and p0122?
anyone know why i would throw these codes? i just did an ls6 intake install and took off egr and totally removed air and air pump at bottom of the car.
Old 03-27-2007, 06:09 PM
brad8266's Avatar
MAF Low frequency and low TPS voltage. Check all grounds and wiring around the intake/TB area. Also clean the MAF with electrical cleaner.
Old 03-27-2007, 08:52 PM
i'll do that when i finish socking down the intake tomorro. also the factory manual says if theres any unmonitored air not going through the maf like a vacume leak or something then it could trigger that code. remember i started the car without the maf and stuff on my car and got coolant into my ports? well i bet that triggered the code when all that unmonitored air whent through but we will see.
Old 03-27-2007, 08:55 PM
brad8266's Avatar
thats very possible. Get it back together and cleaned up, then reset the PCM and see if the codes come back after a few complete heat cycled drives. It takes a few complete heat cycles for the PCM to go into "ready" mode and it wont throw codes until it is in ready.
Old 03-28-2007, 06:17 PM
intake is installed. i'm not geting the same codes as yesterday. i'm getting 2 different codes now but they are the same thing. P0121 tps/pedal position sensor a ckt range/perf. also my traction control will not turn on and when i put the car into drive it surges on and off.
Quick Reply: codes p0102 and p0122?
