Vortech Mondo Dump to atmosphere or back into piping?
Hey guys I'm about to go with a blower setup and I have a vortech mondo blow off valve do you guys dump it to the atmosphere or back into the piping? I heard from a mustang guy that with a MAF car you have to have a sealed intake system?
Also I'm planing on running about 8psi for now is it worth running meth for later?
Any pic's of it mounted would be cool also.
My Mondo is right before the air hat feeding the air door and single plane manifold. It dumps almost straight down into the blower inlet adapter. I have never heard it work.
I am a SD setup though, which is nice for FI. Consider converting to SD? Cleaner, lower restriction plumbing is a plus as well.
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Jim
Have you ever checked at idle to see if there is air flowing into the Mondo since it is open at vacuum? Mine does if I have the bypass hose off. Hate to see you possibly getting dirt into that beast.
Jim
Jim
I'm learning, so why do you need to run a filter on it??
Simple to check - at idle just put your hand on it. If it sucks, you need a filter. At the very least I'd put a screen on it.
Jim
Cool. Obviously a different layout. I would recommend a screen at a minimum and also state that I would use a oiled filture like a K&N. Since you never know when an air draw through the Mondo will occur, it pays to be safe.
Jim
Jim
TECH Cry Baby BOSS APPROVED!
Originally Posted by Vortech
I was under the impression the blow off-mondo is not supposed to be venting air at idle conditions-that is unless of course your vacuum at idle is 16 HG or higher.
Its strange I just looked at my Mondo & I dont have the 2 littel brown filter things on mine? I dont even have littel holes where do normaly go...
Also is it ok to have a Mondo that doesnt dump back into the pipes on a MAF car?
