ls6 cam
Old 03-28-2007, 03:44 PM
BurtReynolds's Avatar
Default ls6 cam
I am getting the ls6 cam put in and was wondering what rpm I should raise it up to.
Old 03-28-2007, 04:11 PM
onecamaro1's Avatar
i didn't raise mine any, it's fine
MightyBobo's Avatar
Isnt the redline for those 6K? Either way, just curious...why not something slightly larger?
Old 03-28-2007, 04:16 PM
ilirw325's Avatar
Stock Z06 LS6 revlimiter is 6600 If I remember correctly
But that is with the supporting LS6 heads which have stiffer springs and lighter valves.
Old 03-28-2007, 04:18 PM
onecamaro1's Avatar
with the 918 beehives, i did 6500 and it was trying to pull hard past the limiter, i'll try a little higher.
Old 03-28-2007, 05:47 PM
Chris81's Avatar
I have my limiter at 6600 and shift around 6500, it pulls to the limiter without falling off.
Old 03-28-2007, 09:45 PM
Evans752's Avatar
6600 but shift it at 6500, good luck.
