N4cer
03-28-2007, 06:31 PM
I'm very strongly considering this. But I've noticed when digging through some of the threads, it's hard to come up with consistent answers. And the ones I can find have some wording issues that make it hard to understand. I think it would be great if these parts questions could be answered here.
1. 4L80e Transmission
Will a stock one hold with my mods and 150 shot?
2. Torque Converter
2a. What one do I use?
2b. A 4L80e converter?
2c. Who makes one in about a 3400?
2d. Or will another type work?
2e. Even with the spacer, to save a few bucks?
3. Flexplate
What one do I use, and does it bolt up directly?
4. Engine Harness
Going to use an auto harness with the adapter to run the 4L80e. Does the PCM still require the HPtuners file to be sent in? Or is this usable now without sending it in?
5. Harness Adapter
See above for related questions.
6. Drive Shaft Fix
6a. What needs to be done?
6b. Can I have my 6-speed drive shaft shortened if needed?
7. Crossmember
Can I fab one from my 6-speed crossmember?
8. Tranny Cooler
What's one that fits well? (Yes, I'll use a stock auto radiator, so that I can use its built-in cooler, but I know I'll need to add an aftermarket one.)
9. Pedals
Will it suck to leave my stock pedals in so that I can switch back later? I guess if pedals are cheap, I can always switch them out.
10. Shifter
10a. What one(s) fit best?
10b. What modifications will need to be done? I assume a new hole in the tunnel and covering the old one.
11. Dipstick
What do I use?
12. Have I left out anything? Any special considerations? Any comments?
2. Torque Converter
3. Flexplate
4. Engine Harness
5. Harness Adapter
6. Drive Shaft Fix
7. Crossmember
8. Tranny Cooler
9. Pedals
10. Shifter
11. Dipstick
What do I use?
