05 CTS-V - no PCM or key
I picked up an 05 CTS-V that went off road. The PCM along with connectors were torn off. It also does not have a key.
I have a complete key, bcm, PCM from a 1999 C5 Corvette. Is there a chance of getting around or incorporating the V stuff with the C5? I researched and are the V stock computer is a more robust than the older C5.
Thanks,
Norm
Thanks,
Norm
I've got a PCM to match the vin but wondering about the ignition key to bcm. The dummy key only turns to the on/start position and lights up the dash. Will I be able to turn off vats once the PCM is powered up through HPtuners or will the bcm be looking for a mated key before being turned off?
Norm
Norm
