shift points
It can be. It is very user specific. Some drivers may like the current shift points, others may prefer a delayed shift points ... not an easy one fits all scenario. The tables are MPH based, just primarly log: TPS%, MPH, Engine RPM, Trans Current Gear and TCC Mode ... this should help you fine tune the shift points you desire.
Is there a screen that you will go to that will allow you to put in a mph # for either the shift point or down shift (for each gear of course), or is it more complicated than that?
