fresh cam install how long before wot
is there any break in period besides the few heat cycles on the springs after a cam install. in other words how long did you wait after cam install to get on it? im anxious to see what she has. thanks
nathan,
nathan,
oh yeah good pt . i got my wide band in about 2wks after the cam and found out that like abve 5k it would lean out to 17:1. i could feel it and i noticed that the O2s dropped off on my laptop. when i first saw 17:1 i about cried i had hit the rev limiter about 10 times before i got the WB working.
Originally Posted by 99blancoSS
says he's tuned in his sig
then he needs to make sure tuning (detonation)is right and a/f (burns a hole on piston) is correct. plus springs do need a heat cycle before wot. cam does not, cause there on rollers. "springs" need it........you mentioned u drove it for several days now, how many times did it cool off other then parking it for the night? 5 or more cycles should be enough. just make sure it's tune and a/f ratio is good.
fuerzaws6
nathan,
nathan,
