help ..Another Question. Middle of cam install
Old 03-29-2007, 08:27 PM
ls1chris's Avatar
Default help ..Another Question. Middle of cam install
well got the motor apart almost completly down ,intake, heads etc well i was goin to pull the oil pump to acces the timing chain to put a new on in .but do i have to drop the damn oil pan also .is their another way to do it .the motor is in the car and i really didnt want to have to drop the pan
Old 03-29-2007, 08:31 PM
brad8266's Avatar
You have to drop the oil pan just an inch or 2 but it does not have to come all the way out. Pretty much unbolt it and let it sit on the K member.
wssexorz's Avatar
drop the pan ... i was in same shoes as you and i didn't want to ... but just drop it inch or two and it will make that pickup tube bolt alot easier to get on/off
Old 03-29-2007, 08:54 PM
MS3Z's Avatar
A gear wrench is your best friend when it comes to unbolting the oil pan.
Old 03-29-2007, 08:59 PM
wssexorz's Avatar
yes gear wrench is almost required for a couple bolts on oil pan and the pickup tube bolt
Old 03-29-2007, 09:02 PM
brad8266's Avatar
A 10mm gear wrench is a standard pre-requisite for working on any LS1 based car.
Old 03-29-2007, 10:22 PM
408 z28's Avatar
thats all there is to it...and as the others said 10mm ratcheting wrench makes **** alot easier for the bolts above the k member
