Torque Converter Code P0757
Old 03-30-2007, 06:43 AM
USRobo's Avatar
Default Torque Converter Code P0757
Torque Converter Code P0757 - Installed a new torque converter, higher stall, and now get check engine light and lose power. Can reset computer but comes back at slow speeds.
C5-Corvette 4l60E Transmission, Something to do with 3/4 shifting or slippage. I understand that it can be edited out with HPTuners.
How do I edit/remove this code in HPTuners.
Thanks,
Old 03-30-2007, 12:55 PM
tjswanson2001's Avatar
This is a common code once you've installed a hight stall torque converter. Go to engine diag. and then DTCs and deselect the codes you want off.
Old 04-01-2007, 12:26 AM
BubaGumpShrimp's Avatar
yes shut it off. had the same problem with mine..
