started my car to today after heads and came installbut
Old 03-30-2007, 08:35 AM
pdd
pdd's Avatar
Default started my car to today after heads and came installbut
its blowing white puffs of smoke out the back like when you first start yr car on a cold day. my whole garage filled with it. any ideas what it is?. i havnt changed the oil yet since the head cam install so i know there must be antifreeze in the oil still but that shouldnt cause this.
Old 03-30-2007, 09:26 AM
massls1guy's Avatar
you might want to move this thread to 'LS1 internal engine'
Old 03-30-2007, 09:27 AM
WhosNXT's Avatar
Mine blew condensation out for a bit after the H/C on the first night we got it running, the next day once the new pcm was installed and I drove it for a while and it went away.
Old 03-30-2007, 09:29 AM
GR33N GoblinM6's Avatar
white smoke is usually coolant burning... check your coolant level... if its down, you may have a head leak...
blueish-tint white smoke is oil burning...
brad8266's Avatar
It should go away after a while. If it doesnt then you need to start by doing a leakdown test.
Old 03-30-2007, 12:29 PM
pdd
pdd's Avatar
sorry-can a mod move this??
Old 03-30-2007, 12:54 PM
Viper's Avatar
pdd
Congrats on getting it running. As mentioned, have you finished filling it with coolant yet?
Old 03-30-2007, 03:16 PM
turbotko's Avatar
If there's coolant in the oil the PCV system might be picking it up as the coolant boils off. I wouldn't run that sucker very long with coolant in the oil. It tends to do nasty stuff to bearings and such.
Old 03-30-2007, 03:31 PM
pdd
pdd's Avatar
Originally Posted by Viper
pdd
ya shes filled to the the top
Old 03-30-2007, 03:34 PM
did you spill any coolant into the cylinders when changing heads? did you get it out when you put the new heads on?
Old 03-30-2007, 06:39 PM
pdd
pdd's Avatar
ya sum went in, but i shop vac'ed it out right when it happened. i started the car again and now theres not as much white smoke but water was coming out the tailpipes. ill change the oil tomorrow ill start it again to tomorrow and see what happens. wish i new how to rec with my cam. car souds ****
Old 03-30-2007, 06:42 PM
brad8266's Avatar
water out the exhaust is OK. Dont worry about that.
Old 04-01-2007, 01:01 PM
pdd
pdd's Avatar
OK. i cant wait to get the new brakes on and take her for a rip. havnt drove the car since nov
Old 04-01-2007, 10:46 PM
BLOWNALKY's Avatar
I wouldn't run the engine with any coolant in the oil as water is heavier than oil, would therefor sink to the bottom of the pan and subsequently be the first thing circulated through the oiling system. Water is not a good lubricant and antifreeze is even worse. At least they are no good in high load situations, such as between bearings and cranks, etc.
As for the startup smoke, if there is any chance that some coolant spilled into an upturned exhaust pipe when you lifted the heads off then you would have considerable amounts of white smoke shortly after startup. It would last a considerable amount of time before it all burned out (30-60 minutes?). In this case it would not be a cause for alarm.
jack.
Old 04-02-2007, 11:51 AM
1LE4ME's Avatar
Any time that a cam or heads are swapped I have the oil drained because of the chance of coolant getting into the oil. It's not much of an expense to buy oil compared to the price of an engine. As said above, anti-freeze will kill bearings. Just a tip.
