HELP! Car is screwing up and I dont know why:
Old 03-30-2007, 01:15 PM
t1blackout's Avatar
Default HELP! Car is screwing up and I dont know why:
Hey Guys,
I was driving the other night and the car started acting funny. I had gone WOT for 3 seconds just for fun and the car started delaying almost as if the traction control was kicking on (even though it was disabled)
A few miles down the road and I started to notice some funny bogging (felt like the transmission wouldnt lock up and unlock correctly). It almost felt like the car was flooding itself or something.
I stopped at a stoplight and the car cut off, and from that point forward I had to keep the car reved up or it would die. I was in the city and every stopsign the car would die so i had to quickly pop it in N and keep the RPMS above 2,000. I got the thing home and now I dont know what the hell to do with it.
Any chance that this is the transmission causing the problem or is it the MAF or something? I hooked up the predator and it was throwing some MAF codes. Should I just get a new one or should I take it to someone.
Thanks guys!
Old 03-30-2007, 01:41 PM
bczee's Avatar
Did you check out the MAF.. screen plugged or the ports plugged ?.. are there any plugs or wires loose ? gaskets, leaks ??
Check out what you can and keep us informed.
Old 03-30-2007, 01:48 PM
t1blackout's Avatar
I checked the MAF and nothing is clogging it... The plugs all seem fine too but I dont know what else to check... Does this sound like a MAF problem? Maybe I should buy a granatelli MAF or something...
Old 03-30-2007, 01:50 PM
bandit4's Avatar
It Is For Sure A Maf Problem.
Old 03-30-2007, 01:53 PM
t1blackout's Avatar
should I just get a bad *** one from some website, or should I get a stock one? any suggestions?
Old 03-31-2007, 01:39 AM
t1blackout's Avatar
nothing else? what should i do guys? new MAF aftermarket or should i get a stock used one on here?
Old 03-31-2007, 02:56 AM
BLKWS.6's Avatar
My car did that when the fuel pump died. Didnt throw codes though.
Old 03-31-2007, 03:03 AM
BLKWS.6's Avatar
Try cleaning your current MAF.
Old 03-31-2007, 06:36 AM
Kage's Avatar
Cool
Try cleaning it real good, find out for sure that is your prob.
If it is i'll sell you my OEM MAF.
Old 03-31-2007, 12:12 PM
Z28LS1camaroguy's Avatar
ive got a stock 98 MAF sensor for sale 50 bucks if your interested, i think it will work with a 99.
Old 03-31-2007, 09:02 PM
ArcticZ28's Avatar
I'd go with a stock replacement. No sense in buying anything else... if it is the MAF.
Old 03-31-2007, 10:05 PM
craz28's Avatar
I am with the rest of the guys, get a stock MAF
Old 04-01-2007, 12:03 AM
01WS6/tamu's Avatar
oe only
Old 04-02-2007, 09:37 AM
t1blackout's Avatar
the OE is $200 bucks from the stealership. Should I just get that or should I buy an aftermarket one for around the same price?
Old 04-02-2007, 09:43 AM
Kage's Avatar
Cool
I'll sell you my OEM with brand new ported ends from PFYC for $90 only has 26,000 mi on it.
Old 04-02-2007, 09:49 AM
mattraypharbor's Avatar
It might be in the Tune did you just recently swap cams?
Old 04-02-2007, 10:49 AM
ArcticZ28's Avatar
You can try SDPC, GMPartsDirect, Ebay...
