General Maintenance & Repairs - loud grinding when trying to start motor!!!!!!!!
fstls2camaro
03-30-2007, 06:05 PM
i just replaced the lifters in my car and i went to try to start it and it turned like one time and quit it did that twice now when i try to start it it makes a loud grinding noise but is not turning over the motor my battery is still good it shows 11 volts on the gauge what could be wrong.
keliente
03-30-2007, 08:12 PM
11 volts is not enough to get you started, meng.
VIP1
03-30-2007, 10:46 PM
Is it a grinding noise or loud rapid clacking/clicking?
Keliente is right. 11V is not enough to start the engine. You need to jump it. When there isn't enough power to start the engine, you'll get a loud rapid clacking/clicking sound.
Have the battery tested. You may need a new one.
fstls2camaro
03-31-2007, 02:59 AM
it is a loud grinding not a clicking noise i know what a starter with not enough power sounds like but it doesnt sound like that.
WS6nJAX
03-31-2007, 03:17 AM
you may want to charge/jump the car just to be sure. a little more info on the work done to the car also might help if thats not it. lifter type, new or used, reason for the swap, things like that.
fstls2camaro
03-31-2007, 11:09 AM
i put new ls7 lifters in it because i had one collapse.im going to jump and see what happens.
