Need some help new to ls1's
Im familar with bbc and sbc but not so much ls1's. And i was looking at some advantages of the ls1 and have now thought about using one.
So a couple simple things i couldnt find when i searched. How much hp can the ls1 aluminum block handle? I am thinking about putting it in a 70 nova, since it will defently give some weight reduction.
Would i be able to use this rotating assembly with the aluminum block it would have to have some lower comp pistons because i plan on running a procharger.
http://www.cnc-motorsports.com/produ...32&CtgID=10374
Also if the above will work together will i be able to run an f1 procharger and like 16-18 psi on 93 octane? Looking to make like 750 rwhp at the least, what do you guys think?
