Suspension & Brakes - So I re-did my SJM ABS/line lock... pics
waterbug1999
03-31-2007, 06:42 PM
What it looked like before....
http://www.geocities.com/jody_abbott2000/Engine5.JPG
And after I re-did everything.... Not too shabby eh?
http://www.geocities.com/jody_abbott2000/ll.JPG
black_z
03-31-2007, 07:10 PM
Looks good Jody. I need to fnish mine up!
MeentSS02
03-31-2007, 07:11 PM
That looks REALLY nice...care to elaborate on how it was done? I still haven't installed mine (no time), but love the clean look in the second pic.
waterbug1999
03-31-2007, 07:12 PM
it took all dam day..... trial and error.
MeentSS02
03-31-2007, 07:13 PM
Yes, but that is the ONLY way to get something that comes out like that...just the way you like it, and like it was meant to be that way from the factory.
waterbug1999
03-31-2007, 07:21 PM
I pretty much just went to the auto store, bought a 5' 3/16 stick and the bending tool plus some fittings and started mocking it up.... I rigged up my own bender (took the tool apart) and it worked alot better.
Duffster
03-31-2007, 11:14 PM
Looks much MUCH cleaner now.
Might I recommend for the next person to try this, use either a cut hanger or pipe-cleaners to get the sizes & angles you want for templates?
I need to redo mine to clean them up a tad and this is my plan...hope it helps.
-Freak-
03-31-2007, 11:56 PM
Looks good!
I see you got bored and did the wire delete mod also.
Where the fuck is your tranny, i think you have waited long enough.
Duffster
04-01-2007, 07:36 AM
Now, drill a 9/16" hole in the drivers side and hide that hood release cable...
waterbug1999
04-02-2007, 01:04 PM
Looks good!
I did the wire mod last year when I was waiting for my 1st tranny (POS Rock - ON) to get here..
This tranny ought to be here enither end of this week or next week for sure. Ill call FLT end of this week. I am still waiting on my NASTY fuel rails as well.
Jimmard
04-02-2007, 03:16 PM
Doesn't SJM sell premade lines? How do those look?
waterbug1999
04-02-2007, 03:45 PM
Something very similar to the 1st pic.
LS1BADZ
04-06-2007, 12:13 AM
Nice job....looks like mine :jest:
http://i106.photobucket.com/albums/m268/Newbombz/linelock.jpg
Sweet. Can't wait to do mine.
JL ws-6
04-06-2007, 04:45 AM
looks a ton better with the factory flex lines outta there. I plan on doing one of those along with a manual master eventually, and redo all the brake lines on the car while I'm at it, run a single line to the back and T it off back there, run the new fron lines along the aftermarket K member which will go in at the same time, etc.etc.
And get rid of all that abs woring like I see you did. How hard was that too by the way, did you just cut and insulate them, or actually snake them all out?
NSTY WS6
04-06-2007, 06:39 PM
Wow, that looks really good. I was going to keep my abs, used the air pump bracket, and the top of the anti-lock bracket, and made a single piece so the anti lock box is where the air pump used to go. I havent bent the lines yet. This would be so much eaisier, its just that gm's anti-lock works so well.
How does it stop w/out the abs?
waterbug1999
04-09-2007, 12:41 PM
I have not had ABS on the car for several years now and just recently decided to get rid of the ABS block.... I dont miss it.
Kevin Doe
04-09-2007, 01:01 PM
very nice install. Looks factory.
