Help with 6.0 possibilities!!!
Currently have the ls1 in my car and I was thinking of picking up a 6.0 and slowly building it over time to swap in my 99 z. Would this be a better choice than stroking my current motor? Don't know if I'll do a power adder or not. Where is some general info on building one of these motors? Also, I found an escalade motor, is that a good one? Just need some basic info! Thanks!
Originally Posted by garrettpen
L92 heads on a 6.0 would be a nice combo
I also just picked up a LQ9 engine, but I think I'm going to keep it stock and install the l92 heads, l76 intake, and a vindicator cam. I just talked to SDPC and the tech guy said everything will bolt up, but would need new rockers for the offset and adapters for the knock and cam sensor.
Isnt the LQ9 a 377 as opposed to the 364 LS2 and LQ4? I saw that in "how to build high-performance chevy ls1/ls6 V-8s" book. I never heard that before...
Also, the LQ4 and LQ9 are supposed to be like ls1s (meaning all of our sensors will go in no problem like its the same engine only 6.0 and iron)...where as the LS2 needs a wiring harness adapter for certain sensors...?...
I am planning the same deal as CMKworm, and I've had my eyes on the L92 heads for a while. The SLP L92 head kit is bound to be a rip off, because its SLP. Would it be cheaper to buy everything on your own? Like from SDPC? Or is this actually a good deal?
http://www.slponline.com/view_product.asp?P=12293 $2295.95
Check out this info,
https://ls1tech.com/forums/dynamometer-results-comparisons/687816-new-ported-l92-results-great-numbers.html
Nice numbers for 6.0 displacement
