LQ9 vs. LS1 ??
Old 04-01-2007, 01:17 AM
Pro52R's Avatar
Default LQ9 vs. LS1 ??
Ok..
I'm still learning...
I've been pondering this for awhile..doin all the homework i can.
If you had 2 engines..LS1 and LQ9.
The LS1 has a cam,ls6 intake,and bolt ons..
Just ballpark,how much more power would you net from a LQ9 w/ cam,ls2 intake,bolt ons?
Is the LQ9 just an iron version of the LS2?
I've seen the article were GMHTP took an LS2..added L92 heads L76 intake and a cam..made 530+ (i forget) hp....
Could you make those same gains w/ the LQ9,L92 heads,cam,etc?
Yes i know the LQ9 would be heavier,but like i said...homework...wanna learn as much as I can before i do anything
Old 04-01-2007, 09:58 AM
PREDATOR-Z's Avatar
530 fwhp, yes. I run a H/C 370 iron (same as LQ9 but bored .030), I'm making 450rwhp which translates to about 520fwhp
Old 04-01-2007, 08:55 PM
Pro52R's Avatar
anyone else?
Old 04-01-2007, 09:42 PM
the_merv's Avatar
I am building an Iron 6.0 with that Heads/Intake combo, we will see..
Old 04-02-2007, 07:40 AM
00 Freak's Avatar
I would also like to know. I'm in same shoes as you are man. It's funny cause it started with just wanting a cam now I think I can pull it off with a Lq9 if the price is right. Please all the info would help.
Old 04-04-2007, 11:08 AM
IOwnNoLS1's Avatar
My buddy... "2slot/a" is dropping in an LQ9 with absolute speed stage II heads, .612 custom grind cam, diamond pistons, new crank, underdrive kit.... and a bunch of other bolt-ons...it should be up and running within the week. I'll only have 9:1 compression, but that's to leave room for alot more air in the future...
I'll let you know what it puts down through the 9".
~Brian.
Old 11-25-2010, 02:15 AM
anheuserbusch08's Avatar
~Brian.
sorry to bring this up but did it ever put down 9's?
Quick Reply: LQ9 vs. LS1 ??
