Tires for Higher HP FI cars... ? ?
Old 04-02-2007, 10:19 AM
nmp27's Avatar
Default Tires for Higher HP FI cars... ? ?
If you daily driver your FI car, I need some ideas on what to get, the 305/30/19 PS2's are TOAST, I realize that I might have to go down to an 18 to get a drag radial or something like that, need some input!
Thanks!!
Old 04-02-2007, 10:28 AM
speedracer5532's Avatar
Nitto Drag radials. Good all around tire for daily driving.
Old 04-02-2007, 10:47 AM
MIGHTYMOUSE's Avatar
i am happy with the new mt 17" 315 thus far at 14psi boost and 30 in the tires..
Old 04-02-2007, 11:01 AM
The Mickey Thompsons are great in the dry but suck bad in the rain.
Old 04-02-2007, 11:03 AM
alwaysinboost's Avatar
I'm using MT ET street 26x11.5x16" with bias-ply tires up front. Traction isn't an issue with 700hp. These are dry weather tires only though, I wouldn't even think about trying to drive them in any kind of rain.
Old 04-02-2007, 11:58 AM
i doubt you are referring to the ones i am. they have a different tread design.
275/40*17" mt vs 315/35*17
Old 04-02-2007, 11:59 AM
i would not daily drive on a full slick or et street, but i do on these radials.
Old 04-02-2007, 12:07 PM
obZidian's Avatar
MM, dude, i don't think i would ever drive in the rain with the MT's. Good tire for hooking with all that solid rubber but in the rain, that non-split rubber wont cut through water and make pockets between the tire and cause sliding.
However, if you have good experience with them in the rain, let me know... im in hte market for some better tires than the nitto's i run.
Old 04-02-2007, 12:12 PM
NA$TY-TA's Avatar
Those do look like they would do better in the rain.....
Old 04-02-2007, 01:13 PM
nmp27's Avatar
Wow, I like the 315/35*17, I wonder if that damn thing will fit under the car without a hammer?
Nick
Old 04-02-2007, 01:29 PM
Blake01SS's Avatar
Ive had Nitto's, BFG's, and MT Drag Radials. Nitto's were good in the Rain but they wouldnt hook to great. BFG's were next and they did pretty good in rain as well, but wouldnt hold a hook at the track. Now my MT's I Love, but DO NOT drive in the rain with them.
By far the MT's hook the best but are the absolute worse in rain.
As far as fitting a 315/35/17 under your car, YES it will work (the BFG's I mensioned above were the same size). No Beating/Grinding Required.
Blake
Old 04-02-2007, 02:20 PM
Speed's Avatar
What wheels are you guys running with the 315s?
Old 04-02-2007, 02:24 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
MM how many miles u think ull get outta those new MT's and where did u order them from?
Old 04-02-2007, 02:33 PM
RW99's Avatar
Hey, the MT's are finally out?!?!?
MM, can you comment on the actual width of the MT 315/35/17 vs the BFG DR 315/35/17? I went from 315/35/17 Nitto's to the BFG's and a hammer was needed. And how about the tread depth? The brand new BFG's looked about the same as the worn Nitto's they replaced! Very shallow...
Old 04-02-2007, 04:51 PM
NA$TY-TA's Avatar
Check in the Tires and wheels section.... there was pick's comparing them side by side..... 1 believe off the top of my head the MT were 1" wider....
Old 04-02-2007, 04:57 PM
ddnspider's Avatar
where to buy the new M/T's?
Old 04-02-2007, 05:03 PM
Blake01SS's Avatar
Yea, dumb post on my part. I was running the 11" TT2 wheels on the rear. Sorry.
Blake
Old 04-02-2007, 05:43 PM
the local shop i got them from orders through Keystone.
they get driven in the rain just like the 275's i had get driven in the rain.. if rain is between me and where i need to go.. i go slow
Old 04-02-2007, 06:05 PM
SSilverSSurfer's Avatar
your correct sire
Old 04-02-2007, 06:09 PM
germeezy1's Avatar
I am pissed because the Nitto555's I run have no traction and there isn't a tire in the 20 inch sizes as far as DR's go. So it sucks because I want to run my 19/20 combo in the summer and would run DR's in the back if I could.
