Dynamometer Results & Comparisons - 462rwhp-stock heads
View Full Version : 462rwhp-stock heads
pdd
04-02-2007, 07:42 PM
http://forums.corvetteforum.com/showthread.php?t=1663318
98SS2836
04-02-2007, 09:20 PM
That's nuts i don't know if I can believe it or not. I don't know anymore.
Ill be in the drag section if ya need me.
Patrick G
04-02-2007, 09:33 PM
I believe it. That's a BIG cam and he's got LS6 heads. The heads alone give him a 20 rwhp head start over LS1 heads. I've tuned a few T-Rex cam only LS1 headed cars (FAST 90/90, headers with HVMC) and gotten over 450 rwhp so 460ish with LS6 heads is believable.
brad8266
04-02-2007, 09:42 PM
Ive heard the rumors about the dyno that was used too. Not sure how much truth is in that claim though. Either way good numbers.
Id still take a way smaller cam with a decent set of heads over that giant cam any day.
98SS2836
04-02-2007, 09:50 PM
I can see it. It's a vette too. They seem to be dynoing higher than our f-bodys.
Demonicbird00
04-02-2007, 10:14 PM
i can beleive it cause it has the 243 heads. its very possible.
-brandon
santiago
04-02-2007, 10:34 PM
Id still take a way smaller cam with a decent set of heads over that giant cam any day.so your sayin you want to spend more money for the same hp
SHINER
04-02-2007, 11:31 PM
I dunno I had 243 heads and I gained maybe 10 hp.
Maybe the dyno needs to be re calibrated or something.....Hard to believe, but look at T56 Rebuilds.com's car it was pushing almost 500 rwhp cam only.
SSNISTR
04-02-2007, 11:32 PM
I think he's sayin he'd rather have a better driving car....
santiago
04-03-2007, 12:33 AM
thats great for him....have fun spending more money for a better driving car.
pdd
04-03-2007, 12:56 AM
vettes dyno lower because of the IRS :judge:
Patrick G
04-03-2007, 01:00 AM
Vettes dyno higher when they run long tubeheaders with HVMCs like the LG Pro long tubes. :) Us F-body guys don't have near as good of exhaust as the Y-body crowd. :(
Slowhawk
04-03-2007, 05:48 AM
I've found Vette's have always dyno'd higher.Anything is believable nowadays.The sad part is that we've dyno'd alot of these high hp cars from other shops and they lose a ton on our dyno.
WS6FirebirdTA00
04-03-2007, 06:14 AM
Biggest difference is what you use it for. If you dont care about low end torque go the cheap route, if you want it and still want to make power up top, you have to set the combo up to work together. I agree with him, I would much rather my setup and the low end it has over a high end screamer, but I drive my car on the street 99% of the time and 1% at the track.
BadAzz96Z28
04-03-2007, 06:30 AM
:jest: NO, thats just not possible......
brad8266
04-03-2007, 06:33 AM
It aint about peak HP man. :) There are other things such as drivability issues that big cam only setups just dont have for the most part.
I like to spend my $$ on a well thought out setup, not a cam only setup. Just one mans opinion, none of you should care what i do with my $$ anyway.
brad8266
04-03-2007, 06:37 AM
It is fun spending money on a better driving car rather than a big peak hp street dog. Im not saying that the car in this thread is like that but that is the case with lots of cam only cars. Either way dude made big numbers. :cheers:
98SS2836
04-03-2007, 06:51 AM
not lower than my 4.30'ed 33 spline 12 bolt with a nice 3in steel drive shaft. :cry:
RobbieTransAm
04-03-2007, 06:58 AM
I totally believe it. I am making 431 with the same cam, same dyno, LS1 heads, and LS6 intake. Numbers seem on point for the mods. Nice numbers man.
bad95killer
04-03-2007, 08:11 AM
Very impressive numbers with cam only.....MS4 :devil: :devil:
peace
NoGamesLS1
04-03-2007, 11:46 AM
Im rollin a trex. Its drivable...sorta :devil:
brad8266
04-03-2007, 11:55 AM
lol @ sorta. My car drives like stock just more powerful, I can shift at under 2k in all gears with no issues at all. Most cam only setups you will not shift at 2k without some nice bucking and surging.
miami993c297
04-03-2007, 11:58 AM
Can you elaborate please???
Christian
pdd
04-03-2007, 12:04 PM
thanks for the info :)
NoGamesLS1
04-03-2007, 01:09 PM
Well I dont quite have the tune it needs yet hence the surging at low rpm. But 3k rpm and north is like a drug...you just cant get enough :)
brad8266
04-03-2007, 01:14 PM
Hey do you have any power #'s on your trex?
NoGamesLS1
04-03-2007, 01:25 PM
with a 393, 90/90, stage II ls6 heads, M6, ls7 clutch, safe tune ~510 rwhp. Since then the heads have been changed. I now have AS stage 2.5 5.3 heads and upped SRC from 11:1 to 12.5:1, went to an aluminum flywheel, yella terra, and switched from 1 3/4 hookers to 1 7/8 kooks. I expect to be north of 550rwhp when tuned. I LOVE this cam. I just needs a good tune. At 3000rpm V-tech kicks in :jest: Turns from docile to an animal
brad8266
04-03-2007, 01:30 PM
LOl @ vtec:jest: yeah the trex on a 393 isnt nearly as radical as it is on a 346. nice numbers.
NoGamesLS1
04-03-2007, 01:33 PM
Thanks I anxious to get a good tune in it. And install the bottle I have laying around :devil:
brad8266
04-03-2007, 01:46 PM
The trex or MS4 would probably be my cam of choice on a 402 or something of similiar displacement.
98camaroLS1M6
04-03-2007, 02:58 PM
Good numbers and very believable too!
santiago
04-03-2007, 03:01 PM
It is fun spending money on a better driving car rather than a big peak hp street dog. Im not saying that the car in this thread is like that but that is the case with lots of cam only cars. Either way dude made big numbers. :cheers:to each their own i guess cant argue with that :)
Red99TA
04-03-2007, 05:31 PM
I believe it...the thread said 453 after SAE correction. He's got better heads, a bigger cam, and probably better tuning than me (I tune myself) so I can see a 25 RWHP gain.
brad8266
04-03-2007, 05:56 PM
Youre one to talk with your big Ci motor, TFS heads and big cam, lol. Sounds like a sweet setup you have.
santiago
04-03-2007, 06:07 PM
Youre one to talk with your big Ci motor, TFS heads and big cam, lol. Sounds like a sweet setup you have.well, after drinkin around ten beers its kinds fun to debate about shit.
brad8266
04-03-2007, 06:24 PM
Yeah if you see me arguing on the net like im on a rant im usually at home drinking, lol.
santiago
04-03-2007, 07:33 PM
Yeah if you see me arguing on the net like im on a rant im usually at home drinking, lol.damn well i thought it was jus me and my friends who did that lol :cheers: to that :jest:
cantdrv65
04-03-2007, 07:41 PM
Nope. I'm not sure who started this internet fallacy.....There is NO more loss due to drivetrain than a 10 bolt F-bod. In fact Id counter that they lose LESS through the drivetrain. Add that to the better exhaust system found in the vette and vettes dyno HIGHER than F-bods....
Mike TexaSS
04-03-2007, 07:45 PM
We just did a 2002 Camaro M6 with only the following mods. Lid, 1 3/4" Hooker Headers, Off road y-pipe, SLP loudmouth and the MS4 cam. It dynoed 422 rwhp STD cam only and 412 rwhp SAE. It dynoed 329 rwhp before the cam. The Z06's with boltons are around 370-390 RWHP.
Kraest
04-05-2007, 09:03 AM
You using a 224 or 248?
mike c.
04-07-2007, 04:31 PM
I know dyno jets dyno higher,but this jet must of thought it was christmas giving out #'s like that. Speed inc's dyno jet had my car at 423hp 407tq. The mustang dyno i go to now put me at 370hp 350tq.....big difference. The only change i had was going from 3.73's to 4.11's. I did finally get to 463hp 414tq after alot of changes on that pesky stang dyno.
408zo6
04-14-2007, 09:23 PM
my 02 z06 made 420rw w ms3 w just bolt on's no fast
venom ws7
04-14-2007, 10:54 PM
what ^^^^^^^^ its says 845rwhp 770rwtq LOL
off topic what is your setup
408zo6
04-15-2007, 07:33 PM
845 is my new set up i have a 408 w a 257/266 cam and a 300 shot 420 is my old set up win i had a ms3 and bolt ons keep lol :jest:
