what's up with my parking brake?
Old 04-02-2007, 10:10 PM
LS1 ACE's Avatar
Default what's up with my parking brake?
hey guys and gals. i'm not sure what is up with my parking brake. a few days ago, i was setting the parking brakek and when i pulled it upwards it went higher than normal. i didn't pull it hard or anything, it just reached its peak and it sounded like something broke and continued upwards. it concerned me, but the parking brake was still working fine. now, just a few miutes ago i parked the car in the garage. again, as i set the parking brake, it sounded like something broke and went up higher than usual. both times that this has happened i have not pulled it harder than usual. my question is, is something broken? should i get it checked out? what does this mean? thanks.
p.s: search is down.
Old 04-03-2007, 03:45 PM
blertawho's Avatar
Mine does that as well, so does my friends. One time I was sitting in my car at Sonic and the E-Brake popped and my car started rolling backwards. Thankfully I'm really good about leaving my car in gear when I shut it down, Ive got a M6 BTW. Im not too concerned.
Old 04-03-2007, 05:42 PM
OldeSkool's Avatar
mine too... f-bod quality, yay!
Old 04-03-2007, 07:34 PM
slp#3130's Avatar
mine does it also
Old 04-03-2007, 08:09 PM
LS1 ACE's Avatar
phew! i tought my amazing strength had proved too much for the poor e-brake lever. thanks guys, i appreciate it. now to fix that damn exhaust leak...
Old 04-05-2007, 09:44 PM
Reject's Avatar
mine dose that too, i started to push the release button while i pull up to skip all of the ratcheting sound ****, hasnt skipped or anything like that in a long while, i though i read about that being cuss the cable was stretched... dont know if that's right or not. anyways im wanting to fix that....that's just very annoyin
Old 04-05-2007, 11:00 PM
SLPSS99's Avatar
I thought there was a way to tighten your ebrake up closer to the tranny? I may be wrong but I will check it out.
Old 04-06-2007, 02:07 AM
spykez28x's Avatar
undue your console and see if the silver thing holding the cord hasnet flipped down. Mine used to go all the way up and not engage then i just flipped that part back up and that fixed the problem.
Quick Reply: what's up with my parking brake?
